HOW DO U TAKE OFF THE VIN PLAT ON EG DASH ???
Old Jun 6, 2005 | 01:27 PM
ted's Avatar
ted
Default HOW DO U TAKE OFF THE VIN PLAT ON EG DASH ???
Hi does any one no how to take off the vin plat on a eg dash??? i want to swap it on to my new black dash......Please help me thanks
Old Jun 6, 2005 | 01:29 PM
s2000june's Avatar
yah i wanna know same thing
Kamin's Avatar
Default Re: HOW DO U TAKE OFF THE VIN PLAT ON EG DASH ??? (ted)
they are rivits. you need to pop them out.
not reusable too FYI. also a special rivit that cant be bought if i remember.
Old Jun 6, 2005 | 01:31 PM
IHateJDM's Avatar
Default Re: HOW DO U TAKE OFF THE VIN PLAT ON EG DASH ??? (Kamin)
that's not going to be easy. The whole point is to put them on so the won't be changed.
Old Jun 6, 2005 | 01:34 PM
chads's Avatar
Default Re: HOW DO U TAKE OFF THE VIN PLAT ON EG DASH ??? (IHateJDM)
yea nomatter how you do it it wont look oem. unless you have the correct rivit gun
Chiovnidca's Avatar
Just drill the heads off. Be careful not to gouge up the tag. install them on the new dash with 1/8 inch pop rivits.
Old Jun 6, 2005 | 02:14 PM
ted's Avatar
ted
do i drill for the top or from under it? thanks
Old Jun 6, 2005 | 02:29 PM
Chiovnidca's Avatar
Default Re: (ted)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ted &raquo;</TD></TR><TR><TD CLASS="quote">do i drill for the top or from under it? thanks</TD></TR></TABLE>
I hold them with some vicegrips from underneath and drill from the top.
Old Jun 6, 2005 | 02:47 PM
ted's Avatar
ted
Default Re: (Chiovnidca)
how em i going to be able to reuse the scew to put on the vin on my new dash if i drill off the head ??
Old Jun 6, 2005 | 02:49 PM
slambedcivic's Avatar
Default Re: (ted)
drill them out from underneath of the dash. then re-install the plate using 1/8" rivits. if they dont work, just use rivet washers on the back side of the dash.
Old Jun 6, 2005 | 03:14 PM
Chiovnidca's Avatar
Default Re: (ted)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ted &raquo;</TD></TR><TR><TD CLASS="quote">how em i going to be able to reuse the scew to put on the vin on my new dash if i drill off the head ??</TD></TR></TABLE>
It's not a screw, it's a rivet. Get a new one.
Old Jun 6, 2005 | 03:31 PM
greenblurr93's Avatar
if you can cut off the bottom of the rivit, then when re installing it on to your new dash, glue the bottom of it so it holds, thats what my friend did, and you can tell anything was done.
Old Jun 6, 2005 | 06:10 PM
BlueIntegraBoy's Avatar
I just drilled mine out from the top when I did a blach dash swap. Then re-riveted it on.
racer22
Oct 14, 2007 04:34 PM
crwilliam82
15
May 8, 2007 05:22 PM
perseverance
17
Feb 8, 2007 04:07 AM
1quickvr4
22
May 18, 2005 08:04 PM
navin
11
Oct 7, 2003 06:03 PM
