EG Firewall Mat - Removal?
Old 10-06-2003, 09:39 PM
navin's Avatar
Default EG Firewall Mat - Removal?
Ok guys the firewall mat on my EG needs to go, putting the car on a lil diet. I am just wodnering how did you guys pull it out?
Do you just need to take the dash off, or the underdash components too?
thanx
Old 10-06-2003, 10:54 PM
TurboBumblBee's Avatar
Default Re: EG Firewall Mat - Removal? (navin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by navin &raquo;</TD></TR><TR><TD CLASS="quote">Ok guys the firewall mat on my EG needs to go, putting the car on a lil diet. I am just wodnering how did you guys pull it out?
thanx</TD></TR></TABLE>
how much weigh is there w/ the under dash matting?? i currently have my dash out so i can fix a broken heater core and i could rip this stuff out before i put the dash back in.. will the road noise be tolerable?? i have pol motor mounts also, will this make more rattles?
Old 10-06-2003, 11:09 PM
Timmay's Avatar
Default Re: EG Firewall Mat - Removal? (Hybrid95CivicEX)
the matting under the dash weighs alot more than all the tar under your carpet
Old 10-07-2003, 04:17 AM
Former Moderator
B18C5-EH2's Avatar
Honestly bro I pulled mine out after pulling the dash out, but I'd bet that you might be able to get it out by cutting it out if you don't want to pull the dash out.
I wasn't targeting just the mat when I was taking the car apart, so I wasn't really thinking of the best way to get just mat out and reassemble.
I'm sure that the dash being out will make it much easier, unless of course you find it hard to remove the dash.
Old 10-07-2003, 05:59 AM
navin's Avatar
Default Re: EG Firewall Mat - Removal? (B18C5-EH2)
I was goin to remove the dash - now i just learned you can pull up on it and most of it wll come out..
Old 10-07-2003, 06:02 AM
RTFM
v4lu3s's Avatar
i tore mine out
and found that it noise is much more with it compared to removing the tar.
Old 10-07-2003, 06:03 AM
at the jetties fishin'
stackz's Avatar
Default Re: (v4lu3s)
you're going to get a lot of road noise and firewall heat coming through if you pull out that mat...
the 5 lbs max that you'll save by pulling it out in my opinion just isn't worth it.
Old 10-07-2003, 06:22 AM
owen_the_soyboy's Avatar
Default Re: (stackz)
tore mine right out with the dash still in tact.
had to cut a few spots to get the mat around a few mounting tabs.
there is definitely more HEAT from the engine on my feet that I can feel on long drives thats for sure!
not much more noise though.
but really a lot more HEAT on my FEET ! not that it hurts but its noticable.
Old 10-07-2003, 06:59 AM
Doctor CorteZ's Avatar
mine tipped 9lbs on the scale.
I had the dash and heater box out already though.
Old 10-07-2003, 07:27 AM
Former Moderator
B18C5-EH2's Avatar
The mat really is heavier than even some of the tar that comes from some of the tarriest Civics.
Civics are not nice.
Civics are not quiet.
If I wanted a nicer, more refined car I'd not own 3 Civics.
Sometimes people realize that they don't care so much for the creature comforts, so they start tearing things out.
The only thing that gets on my nerves sometimes about my car is the exhaust smell. Is it from the firewall mat being gone? Who knows? I'm also missing my carpet, tar, interior plastics, etc.
It only happens at full throttle and when I shift really hard, like when the header and cat become sepearated briefly at the spring-loaded flanges.
Old 10-07-2003, 08:21 AM
huh?
maybe you had better look into a better sealing joint in your exhaust.
cant be from just removing the firewall mat.
me, I dont get any bad smells in my car except my leaky gastank
Old 10-07-2003, 06:03 PM
RTFM
v4lu3s's Avatar
i get hot engine smells
only thing left in my interior is the seats and shell of the dash though.
i can also hear tranny noises very clearly specially since i switched to synth oil in it.
can hear my intake rattle on hard shifts.
polyhonda
03-23-2008 01:53 PM
perseverance
17
02-08-2007 04:07 AM
memorybox
09-07-2006 07:02 AM
Sassafrass
10-11-2004 09:27 AM
HUBB
04-23-2003 07:27 PM
Quick Reply: EG Firewall Mat - Removal?
