99-00 conversion?
Old Jun 6, 2005 | 12:15 PM
Freshsho's Avatar
Default 99-00 conversion?
Just wondering how easy would it be to do a 99-00 conversion on a 97 hatchback? Is it as easy as 99-00 fenders hood bumber and headlights? Is it pretty much a direct fit? does anyone know.? I would like to get a new CF hood for my car if i was doing the conversion first should i just order a 99-00 CF hood? Any help is greatly appreciated.
Old Jun 6, 2005 | 12:17 PM
screech's Avatar
Default Re: 99-00 conversion? (Freshsho)
hood fenders headlights then there will always be the great dicussion bout whether or not radiator support some say yes some say no but i havent done it so i will not say either way
Old Jun 6, 2005 | 12:21 PM
Dooley's Avatar
try searching, but its true... there is a great debate on if the radiator support needs to be adjusted or not.
Old Jun 6, 2005 | 12:43 PM
NerveAgent's Avatar
I watched my friend do it. It looked easy...I don't know why'd you do it though. Maybe a si front conversion, but personaly i wouldn't do it for just a cf hood. Then you gotta think of paint blah blah..
Old Jun 6, 2005 | 01:39 PM
chads's Avatar
Default Re: (NerveAgent)
the 96 front is better.
get the ctr lip and grill and headlights
Old Jun 6, 2005 | 02:10 PM
LoganMantits's Avatar
Default Re: (chads)
it bolts up pretty welljust a few adjustments and ur good
Old Jun 6, 2005 | 04:01 PM
hybridmyk's Avatar
Do it. The grill is wider than the previous years and gives the car a more updated and newer look. My fren has done it on both of his EKs that were 96-98. He put 00 SI front clip and it looks kewl. Easy bolt on. Only takes about an hour. Good luck n post pix when it's done.
Old Jun 6, 2005 | 04:04 PM
hybridmyk's Avatar
I didnt read your whole post. Yeah you have to do the whole front clip. If you just get a 99-00 CF hood, it will bolt on and close, but you will have gaps next to your headlights and grill. You'll be very pleased with the results when do the conversion. It is subtle, but Honda heads will notice the diff n give ya props.
blackhatchy
94
Apr 16, 2012 04:57 PM
crx_si-r
56
Feb 24, 2008 08:52 PM
stattonmw
22
Feb 2, 2006 06:45 PM
livewire41
Nov 15, 2003 06:24 PM
ITR632
May 17, 2002 06:14 PM
