B18C1 Stalls after warm up
Old Jun 6, 2005 | 11:00 AM
greenblurr93's Avatar
Default B18C1 Stalls after warm up
ok, got the swap running good (or so i thought). it runs fine when cold started, but after it gets to temp while im driving (doesnt do it if not driving) when i push the clutch in to stop the car the engine cuts out, doesnt spudder, just dies.... then when i restart it it will fire up with no problem except the idle will be low and rough. TIA
P.S. i got a CEL today after about 15 mins of driving... it never threw a code while it was just running in my driveway no matter how long it ran for..
Old Jun 6, 2005 | 04:23 PM
Default Re: B18C1 Stalls after warm up (greenblurr93)
no ideas??
Old Jun 6, 2005 | 05:18 PM
sammysnakes's Avatar
what code is it throwing?
Old Jun 6, 2005 | 07:57 PM
Default Re: (sammysnakes)
i was on my way to work when it happend so i couldnt pull it, i will pull it in the morning and post it here, thanks for your reply too.
Old Jun 6, 2005 | 08:44 PM
Brodie Bruce's Avatar
maybe the IACV? Get the code for sure.
Old Jun 7, 2005 | 06:22 AM
Default Re: B18C1 Stalls after warm up (xavenged7x)
ok, pulled it... code 23?? isnt that the knock sensor?? im confused... help!
I also noticed the exhaust cam jumped 2 teeth on the timing belt... so hopefully that will help the problem...
Old Jun 7, 2005 | 09:25 AM
yeah, 23 is knock sensor and that isn't the source of your problem.
If your timing belt jumped teeth that is probably your problem.
Old Jun 7, 2005 | 12:15 PM
ya, i fixed the timing belt, and it still does it every now and then if i push the clutch in at higher RPM's (2k and higher) once it hits 1k and i push it in, its fine... i dont know...
Old Jun 7, 2005 | 06:40 PM
maybe check out the IACV. That can cause strange problems around idle.
calcamaro
Jul 15, 2018 01:56 PM
lsvtec2000
Feb 23, 2009 05:23 PM
B00ST2nR
Sep 17, 2002 09:12 AM
