what will happen if you hook up jumper cables wrong??
Old Jun 6, 2005 | 09:11 AM
hatchinprogress's Avatar
Default what will happen if you hook up jumper cables wrong??
i have a da teg and the bat. was dead so i had a friend pull up his car to jump start mine well put the cables on my bat. and when i went to put the other end of the cables on his car there was a spark(from his bat) i looked at my car and the wires were on wrong (neg. on pos.) and when i corrected the issue the car still will not start....... so what happenend i need to know if i have another problem or if the cable situation will cause a car to not start up????? thanks for any help
Old Jun 6, 2005 | 09:30 AM
dragoncoach's Avatar
Default Re: what will happen if you hook up jumper cables wrong?? (hatchinprogress)
Check the fusable links in the engine compartment. After that check ALL the fuses to make sure they are not blown as well.
Old Jun 6, 2005 | 09:31 AM
Default Re: what will happen if you hook up jumper cables wrong?? (dragoncoach)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dragoncoach &raquo;</TD></TR><TR><TD CLASS="quote">Check the fusable links in the engine compartment. After that check ALL the fuses to make sure they are not blown as well. </TD></TR></TABLE> thanks! now could this cause anything major to the car? or will it just blow a fuse???
Old Jun 6, 2005 | 10:07 AM
PandaBear's Avatar
could be major problem, depends on your luck.
Lucky your battery didn't explode and you are here standing.
Old Jun 6, 2005 | 10:25 AM
solareclipseauto's Avatar
usually its the fusable links in the fusebox in he engine bay
Old Jun 6, 2005 | 10:32 AM
Default Re: what will happen if you hook up jumper cables wrong?? (PandaBear)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PandaBear &raquo;</TD></TR><TR><TD CLASS="quote">could be major problem, depends on your luck.
Lucky your battery didn't explode and you are here standing.</TD></TR></TABLE> damn i hope nothin major..but thats how my luck is(bad)<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solareclipseauto &raquo;</TD></TR><TR><TD CLASS="quote">usually its the fusable links in the fusebox in he engine bay</TD></TR></TABLE> man i hope thats all it is...thanks for all the help guys
Old Jun 6, 2005 | 07:22 PM
hey i fixed it nothin major happened, and thanks for the help
b20racer
Aug 11, 2008 10:39 PM
JSPECJUSTIN
Apr 5, 2007 01:11 PM
redheadcivic
Jun 1, 2004 11:00 AM
daidilus
May 27, 2004 08:59 AM
JDMlyfestyle
22
Jan 9, 2004 10:36 AM
