When replacing struts, do you have to replace mounts?
Old Jun 6, 2005 | 09:00 AM
danz75's Avatar
Default When replacing struts, do you have to replace mounts?
I have a 98 Accord EX 4cyl with 105K. The struts are starting to feel a little worn out and at this mileage, I figured it is probably time to replace them. I am planning to replace them with KYBs and am wondering if there is anything else ( strut mounts, etc) that should also be replaced since it is going to be out? Or anything that I should look out for?
Any recommendations of a good alignment shop in the Mill Creek, WA area for a re-alignment after the job is done?
Thanks!!!
Old Jun 6, 2005 | 10:33 AM
fw190bvi's Avatar
Default Re: When replacing struts, do you have to replace mounts? (danz75)
the top mounts are reused generally...though you can upgrade to an aftermarket pillow mount
Old Jun 6, 2005 | 12:07 PM
danz75's Avatar
Default Re: When replacing struts, do you have to replace mounts? (fw190bvi)
Thanks for that. I'll check it out as I have not heard of pillow mounts before. I assume it has better dampening qualities.
Is there anything else that I should check while I'm pulling the struts out?
D16SohcVtec
Aug 12, 2008 08:03 AM
pubestripe
Oct 3, 2005 09:29 PM
paulzy
Apr 13, 2004 08:58 AM
