Are cable and hydro CLUTCHES the same?(b16)
Is what your really asking is can you use a clutch kit from a Cable tranny on a hydro tranny.
If thats the question i dont know the exact answer. I believe the lever is the same as the hydro but i could be wrong. I would rather get a clutch for the right year.
Well what Im really asking I guess is I have crx with an S1 trans. The clutch may not be
be fried, it may only need a pressure plate or bearing. I guess while Im down there I shoudl just do the whole clutch. There was no usdm crx with a bseries so I dont know what clutch kit to buy, or if i decide to just fix whatevers wrong Im not sure where to get the parts from.
If you have the cable tranny with no LSD use a clutch for a 90-93 Integra, B series with cable tranny. Some of the 91 JDM cable trannies with LSD will work with a Hydro clutch but you need the trow out bearing from a 90-93 teg. I am using a ACT flywheel for a 90-93 teg and a Exedy clutch for a hydro b series tranny, just had to change the bearing. My suggestion is dont buy and Exeddy clutch.
The clutch,pressure plate,and flywheel are the same...the ont differant thing is the throw-out bearing.....My friend used a clutch,pressure plate,and flywheel off a cable trans on his hydro trans...
Nerologic
15
Sep 24, 2003 01:06 PM
