turbo or supercharger?
Old Jun 5, 2005 | 09:12 PM
civicgsrswap's Avatar
Default turbo or supercharger?
i have a 96 civic ex with a gsr jdm swap, and i want to know if i should turbo or supercharge it
Old Jun 5, 2005 | 09:14 PM
1995Ex_Sedan's Avatar
1.C. Posting general modification threads in '92-00 Civic / Del Sol is not allowed. This includes threads like “What should I do to my car next?” or “I have $$$ what should I buy?” Please do a search, as there are many threads on the subject that exist in the archives.
Old Jun 5, 2005 | 10:13 PM
Morning Call's Avatar
turbo
super sucks for high revving engines...
Old Jun 5, 2005 | 11:00 PM
jeffk182's Avatar
Turbo
Old Jun 6, 2005 | 03:22 AM
vsmhatched's Avatar
Default Re: (jeffk182)
I would say turbo, but supercharged is constant power from the start
Old Jun 6, 2005 | 07:49 AM
ChinitodeNJ's Avatar
Default Re: turbo or supercharger? (civicgsrswap)
TURBO!
Old Jun 6, 2005 | 11:02 AM
ant123's Avatar
do u plan to race a quarter mile or more.....superchager will put u up there bcuz it kicks in the lower rpms....turbo however dependeing on the setup kicks in later in the rpms.....5 right b4 vtec....so yeah
Old Jun 6, 2005 | 04:24 PM
hybridmyk's Avatar
Turbo! Super is kewl, but is more of a bitch to install. Turbo = easier install + more potential. Super can only boost up to 14 psi with a jrsc. that's pushing it n ya have to change all your pulleys n stuff. turbo, depnds on how much u build ur motor, but 25+ psi is can be done. 500hp daily driver. Good luck. Post pix when ur done.
Old Jun 12, 2005 | 03:02 PM
daredevil003's Avatar
supercharger is the best way to go, if you want a daily driver and something easier to maintain than a turbo. i have a supercharger on my B-series motor and its great.
Old Jun 12, 2005 | 03:14 PM
papito_85's Avatar
turbo.
Old Jun 12, 2005 | 04:55 PM
I8Stang's Avatar
ppppssssssssssssttttttt....
Old Jun 12, 2005 | 04:58 PM
civiccpedx's Avatar
Default Re: (I8Stang)
go with a turbo, superchargers are good for bigger engines, not little hondas. a v8 can handle a supercharger easily but on a inline 4 it is like strapping a big AC to the thing....
turbo has higher psi potential and uses the waste from the engine to make power, so there is not extra strain
Old Jun 14, 2005 | 09:58 AM
hybridmyk's Avatar
Supercharger is easier to maintain. You don't have to leave your engine on for 5 minutes after you get somewhere to let the turbo and maniflod cool down. But, that's about it. Get a turbo timer, and you don't have to worry about it. Supercharger on the d series got me close to 200 hp, but that was with i, h, e, 65mm throttle body, 310cc injectors, fmu, wires, plugs etc etc. plus, I had an extra small pulley on the blower with a bigger underdrive pulley. This enabled me to boost more than normal. But, the JR supercharger can only handle up to 14,000 rpm internally, so i was pushing it. If you do this on a Bswap, you'll get over 200 hp at 6-8 psi no prob, but then your stuck if you ever wanna go more than that. With superchargers too, you gotta worry about your belts braking n stuff, but that's about it.
I got some frenz that are daily driver turbo, and they got no complaints, no worries. Just run synthetic and change oil every 3000 miles for either application.
For civiccpedx, u r right abou all that, except for the part about strapping an ac to it. Superchargers do take a little power at low rpms to make power, but that is offset quickly by the power that the blower makes once it is spinning. There is a tiny bit of lag, but nothing like turbo lag.
Whichever way you go, you'll be pleased with forced induction. Just know the limits of your motor. If you want longevity, don't go more than 8psi on all stock stuff. More than that, you'll start getting leaks and broken stuff like what happenned to my car. Gud luk!
Old Jun 14, 2005 | 12:33 PM
timisyourfriend's Avatar
Drag 3 turbo kit
Old Jun 25, 2005 | 09:16 AM
YeeJ6's Avatar
Default Re: turbo or supercharger? (JZPerformance)
Turbo sounds like the way to go. superchargers whine when you mash on it... bov sound cool
Old Jun 25, 2005 | 09:19 AM
RTE117's Avatar
Turbo. S/C sucks for I4, especially if it's not cooled.
Old Jun 25, 2005 | 10:21 AM
Will_the_Thrill's Avatar
Default Re: turbo or supercharger? (RTE117)
turbos: require more maintenence (sp?), easier to install, runs off of the exhaust and does not drain power, kicks in full around 4-5k
super: not as much maintenece required, a little more difficult to install, runs off of pulleys so do get more psi u need to change pulleys, drains power, and the power is constant.
its all about preference
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civiccpedx &raquo;</TD></TR><TR><TD CLASS="quote">superchargers are good for bigger engines, not little hondas. a v8 can handle a supercharger easily. turbo has higher psi potential and uses the waste from the engine to make power, so there is not extra strain </TD></TR></TABLE>
Old Jun 25, 2005 | 10:34 AM
Corporation's Avatar
Economic Upturn, WUT
From: Alittle Placed Called None of Your Damn Business.
Default Re: (GreyDel)
Superchargers are good for lower RPM cars, as where turbo is better for a high RPM car. Because of the Honda's higher redline, RPMs you should go turbo because it spools at a higher RPM.
Old Jun 25, 2005 | 11:00 AM
Jorsher's Avatar
I would go with a turbo, as most of the others have said. And depending on the boost level you run, you could have it kick in pretty damn early. My dad got a DSM TD05 for me that I'm gonna slap on my D16Y8 as soon as I get the extra money...and I'll probably run it only 6-7psi...
Old Jun 25, 2005 | 11:06 AM
Ktulu's Avatar
Default Re: (Jorsher)
A turbo CAN be much cheaper if you do your research.
Old Jun 25, 2005 | 11:41 AM
nota-eg's Avatar
Default Re: (Ktulu)
Reported
EGk20pro
Aug 19, 2013 06:26 PM
typeRSXS
Oct 3, 2003 07:25 AM
infamousALLMTR
Feb 23, 2002 09:45 PM
