d15b vtec problems!!
I have no idea how to do this my self all im asking is what to but and then im gonna have a shop do the install! i have a 95 eg cx with a d15b jspec sohc vtec motor. problem is its hooked up to the stoc cx ecu! ive been told i need to buy a p28 ecu but im not sure also i dont know what wiring to but for the vtec! ive seen the vtec harnesses on ebay but they are all for a 1.6l ex or si will that work? so i need to know what ecu and vtec harness to buy! any help would be appreciated
Vtec is wires in your firewall to the solinoid thats all i believe....
P28 ECU will work and a P03 i think? It should plug right in...
I am doing this exact swap also and i hear its cake as long as you get the vtec plug and wires hooked up out of the firewall...
Good luck on a kickass swap
https://honda-tech.com/zerothread?id=1136016
Go tot hat post, it may help you. PM the poster also, hes a good guy and knows his sheeet
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatch It »</TD></TR><TR><TD CLASS="quote">Vtec is wires in your firewall to the solinoid thats all i believe....
p03 is the jdm ECU...just try not to pass smog with it cause you wont...just get the p28 usdm ecu and run the wire for the v-tec...good luck with it...i have same swap but its just sitting here...lol
</TD></TR></TABLE>p03 is the jdm ECU...just try not to pass smog with it cause you wont...just get the p28 usdm ecu and run the wire for the v-tec...good luck with it...i have same swap but its just sitting here...lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPNFEDEJ »</TD></TR><TR><TD CLASS="quote">p03 is the jdm ECU...just try not to pass smog with it cause you wont...just get the p28 usdm ecu and run the wire for the v-tec...good luck with it...i have same swap but its just sitting here...lol</TD></TR></TABLE>
Will the p03 ECU pass emissions in PA? Im on the east coast and we dont have smog here....so i think the ECU may pass? Let me know before i spend 100 bucks on the p03 when i really need a p28 thanks!
skunk2unerz
21
Mar 12, 2016 03:16 PM
LUiS010606
14
Feb 24, 2009 02:06 AM
Tad
May 29, 2004 06:00 PM
