parts needed for b16a swap in crx
Old Jun 5, 2005 | 07:30 PM
EF_FEVER's Avatar
Default parts needed for b16a swap in crx
Okay, I've got everthing. Motor, tranny, ecu, axles, shift linkage and mounts. On the shift linkage is there a bushing on the piece thats round? If so where could I get one and what about the pins or bolts for the linkage? What gauge wire do I need to wire up vtec? Would radio shack carry it? What about the exhaust manifold? Will I have to take it to the muffler shop and how much? (What else should I buy ahead of time before I swap)
Old Jun 5, 2005 | 07:46 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: parts needed for b16a swap in crx (crxb16a_873158)
Search man, is been covered
Old Jun 5, 2005 | 08:39 PM
oneforce's Avatar
Default Re: parts needed for b16a swap in crx (PURPLETERROR)
cant someone help a guy out
Old Jun 5, 2005 | 10:04 PM
bryant's Avatar
Default Re: parts needed for b16a swap in crx (oneforce)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oneforce &raquo;</TD></TR><TR><TD CLASS="quote">cant someone help a guy out</TD></TR></TABLE>
Not when stuff as easy as this has benn covered 8916518918 times already on here. Search, it works very well on this site.
Old Jun 5, 2005 | 11:07 PM
1quickcrx's Avatar
Default Re: parts needed for b16a swap in crx (bryant)
1.) itll be easier to send the wiring off to hasport and have them do it
2.) any aftermarket header will work (provided its a 4-2-1).
3.) hasport shift linkage....problem solved
4.) youll need an acura throttle cable
5.) youll also need radiator hoses from a DA integra
Old Jun 7, 2005 | 08:54 AM
EF_FEVER's Avatar
Default Re: parts needed for b16a swap in crx (1quickcrx)
yep, found everthing I need.
Old Jun 7, 2005 | 09:22 AM
crxtreme89h's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bryant &raquo;</TD></TR><TR><TD CLASS="quote">
Not when stuff as easy as this has benn covered 8916518918 times already on here. Search, it works very well on this site.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxb16a_873158 &raquo;</TD></TR><TR><TD CLASS="quote">yep, found everthing I need.</TD></TR></TABLE>
Classic!
efjones9
Aug 12, 2008 01:53 PM
shackler
Jan 29, 2007 08:29 PM
crx4ever
Jun 12, 2006 09:45 PM
jchrm80
Apr 27, 2006 05:06 PM
b16a27
10
Aug 29, 2005 07:29 AM
