New LoveFab Turbo Exhaust Manifolds with 4" Downpipe!!
<FONT SIZE="2"><FONT COLOR="red">LoveFab Top Mount</FONT></FONT>
- Wastegate Priority *Guaranteed To Hold Boost*
- 44mm Flange
- T3 or T4 Flange
Special Introductory Price if ordered through Kohler Auto $1050
<FONT SIZE="2"><FONT COLOR="red">LoveFab Top Mount 4" Downpipe</FONT></FONT>
- 4" Design
- V-band Flange or 4 Bolt Flange
- O2 bungs welded in
Special Introductory Price if ordered through Kohler Auto $475
Tried and Tested, Kohler Auto Approved
Modified by Jordo@KAP at 5:29 PM 6/6/2005
- 44mm Flange
- T3 or T4 Flange
- 4" Design
thanks Casey! Got your guys' new catalog this year, very well put together!
I think today is Dyno Day for Jordo. Lets hope his car stays together for us
Cody.. Will this flow better, make more power than the minime?
Also when u say its non AC compatible, is it because of how close the manifold is to the front or the AC compressor wont bolt in at all? I could always re route the A/C lines to the rear
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fjt »</TD></TR><TR><TD CLASS="quote">Cody.. Will this flow better, make more power than the minime?
lol, it clears the AC mount, runs right where the downpipe would run I believe...BUT, the compressor outlet has to run right through the belt area, so I would say good luck to that! Maybe Jordo can hold his AC compressor up for us to see?
The only two ways I can see this making more power over the Mini-me is with the more laminar collector and wastegate priority design. Its supposed to raise the volumetric efficiency of the motor because the wastegate doesnt have to say open as long, keeping the manifold pressurized and turbo spooled very precisely. This is my take on things anyway
Oh, this is slightly more "equal length" than the standard Mini-me, this always helps power production(even thought Mini's dont have problems with power production).
And no bracing is present, although you are free to add some if you feel its inadequate; as long as there is movement room for the manifold to grow and contract. I would brace the turbo to a valve cover bolt using rather large holes to allow the brace to "slide around" when the manifold expands/contracts. Or build a Heim joint system
In any case, we havent had a tubular manifold crack since Sept. of 03 (to our knowledge) and with our welding processes, I see no reason for them to start cracking now. Just make sure you have a flex on the downpipe!
</TD></TR></TABLE>lol, it clears the AC mount, runs right where the downpipe would run I believe...BUT, the compressor outlet has to run right through the belt area, so I would say good luck to that! Maybe Jordo can hold his AC compressor up for us to see?
why did cody have to sucker me into the RIP SST sale, why!!!! But anyways, cody makes quality stuff so i'm sure the top mounts are just as good if not better.
i may have to get the top mount for the extra bling factor
GITWIDIT's car may be sporting something new once he gets the motor rebuilt
He mentioned something about a PT72
FIxALPHA
Northeast (Sales)
Feb 24, 2011 03:12 AM
FIxALPHA
Feb 24, 2011 03:11 AM
Hercules
Aug 27, 2008 09:08 PM
B18T3T4
Mar 12, 2007 09:07 PM
