HELP! I was on my way to school when I couldn't start my 97 Prelude anymore?? HELP!
Old Jun 5, 2005 | 04:50 PM
Johnny916's Avatar
Default HELP! I was on my way to school when I couldn't start my 97 Prelude anymore?? HELP!
Hi, when attempting to start my 97 Prelude Coupe (Auto Trans) I can't seem to get it started! It cranks and everything but no actual engine start.
I tried jumping it and it still wouldn't start, so I'm sure the battery is fine.
Please help.
The car only has 91K miles on it, I can't believe something's gone bad!
John A.
Old Jun 5, 2005 | 05:31 PM
01 LudeDude's Avatar
Default Re: HELP! I was on my way to school when I couldn't start my 97 Prelude anymore?? HELP! (Johnny916)
There was a recall for the ignition switch a while back, could be a possible suspect.
Old Jun 6, 2005 | 12:32 AM
K-Spec's Avatar
Does it keep clicking when you turn the ignition? or what?
Old Jun 6, 2005 | 10:10 AM
Johnny916's Avatar
Default Re: HELP! I was on my way to school when I couldn't start my 97 Prelude anymore?? HELP! (khalal538)
No it cranks fine, but just doesn't start the engine..
Old Jun 6, 2005 | 11:35 AM
monalisa overdrive's Avatar
did you check spark?
Old Jun 6, 2005 | 03:25 PM
Johnny916's Avatar
Default Re: HELP! I was on my way to school when I couldn't start my 97 Prelude anymore?? HELP! (monalisa ov
How do I check spark?
Old Jun 6, 2005 | 04:40 PM
PrettyLude's Avatar
take the spark plug wire out and ground it against the valve cover, if you got fire, next check for fuel
Old Jun 6, 2005 | 05:06 PM
Johnny916's Avatar
Default Re: (PrettyLude)
Ok we just did the spark test thing and I do see spark.
So what do I check next? Please include as much details on the procedures as possible. Thanks..
Old Jun 6, 2005 | 05:29 PM
PrettyLude's Avatar
check for fuel next and see if your getting fuel
Old Jun 6, 2005 | 05:49 PM
Johnny916's Avatar
I smell fuel when trying to start the car.. What now??
Old Jun 6, 2005 | 06:42 PM
PrettyLude's Avatar
take the spark plug out and see if gas is getting to the plug
Old Jun 6, 2005 | 07:06 PM
Johnny916's Avatar
Yes they are getting fuel, I can see fuel on them.
Old Jun 7, 2005 | 11:08 AM
lude of pre 2.3's Avatar
well if its getting fuel and spark it should be starting u didnt break the timing belt did u
Old Jun 7, 2005 | 11:18 AM
Johnny916's Avatar
Default Re: HELP! I was on my way to school when I couldn't start my 97 Prelude anymore?? HELP! (lude of pre
No the timing belt was just changed and it looks fine to me.
Old Jun 7, 2005 | 01:21 PM
just for kicks, try picking up a can of starting fluid and spraying that into the intake and/or cylinders, see if that gets it going. worth a shot.
Old Jun 8, 2005 | 09:10 AM
Johnny916's Avatar
Ok found the problem but now I'm a bit upset..
I had to get the car towed back to the shop because
A.) I couldn't find the problem
B.) A mechanic came over my house and told me the timing belt was missing a tooth. (What a knucklehead!!)
However, expecting to have the bill waived because the shop just changed my timing belt a couple weeks ago I just got a call from them and they told me I had bad spark plugs. I certainly couldn't argue with the phone call, I'm not a mechanic. So I just agreed to pay the $85 (including tow) and learn from this mistake.
Yes I did say I had spark because I did! I took the spark plug wires out and inserted ANOTHER spark plug instead of the one's inside my car. THEREFORE, I wouldn't of known if the spark plugs were bad or not. BUT I here's the catch, I just changed them about a month ago!!!! They were brand new!! Which is why I never bothered to thoroughly inspect them. Boy I wish I had inspected them now!!
bsquared135
Apr 13, 2009 11:37 AM
streetjdmrex
Aug 8, 2007 12:59 AM
Johnny916
Jun 8, 2005 01:43 PM
SulphurDave
Dec 5, 2004 05:39 PM
E46M3CB
Oct 10, 2003 05:49 PM
