Speed sensor stuck in the tranny :o
Hey guys the speed sensor on my 90 CRX (stock setup) is stuck in the tranny. I've tried pulling the cable, twisting the part that the cable goes into, everything. Any suggestions/tricks on getting it out
EDIT: By speed sensor I mean the speedo cable
Modified by Phaze2 Nick at 10:32 PM 6/5/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaoss_11 »</TD></TR><TR><TD CLASS="quote">leaving the car in nueutral helps imo</TD></TR></TABLE>
Thanks for the tip.
The car is in neutral...what exactly comes out? Just the cable, or the piece at the end of it as well?
Thanks for the tip.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1gEF-8 »</TD></TR><TR><TD CLASS="quote">did you remove the retaining clip
That could explain a lot, where is the clip located? I need to check the manual
Tampa Native
Feb 25, 2008 06:05 AM
