97 Accord Strut bar question
It looks like on the left side of the engine bay you might ahve to re-locate some wiring to install a STB. Is this correct? On my 97 Accord there is a bunch of wires that is located right next to the sturt location and appears as if it would be in the way of a tower bar?
can anyone verify this? Or show some pictures of what has to be done, if anything at all?
In my 92 accord I had to move some wiring harnesses that were clipped onto some metal that was right by my passenger front strut tower, they just pop off and go down. Probly about the same thing for your 5th gen.
was it hard or does it need to be done carefully?
Im just a bit worried, i dont want to f*ck with my wiring and all and get screwed over all b/c of a damned tower bar
just move it like a normal person would.....just dont yank on it and rip a wire out of a connector....if you can imagine how much grime and abuse they see over the course of normal driving, its not a big deal just to move them
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drifter_for_life06 »</TD></TR><TR><TD CLASS="quote">im getting a Megan-Racing one</TD></TR></TABLE>
they should sponsor your
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DJ14aZnS »</TD></TR><TR><TD CLASS="quote">since this is about strut bars.. can sum1 refresh me....
bigger bar in rear = more overstear
small/tight bar in front= less control?</TD></TR></TABLE>
thats really only with sway bars......rear, or front, strut bars are basically to stiffen up the chassis, not to change suspension geometry...
strut bars are a
......lower tie bars are a
strut bars are a
hmm im confused struts connect on top of the shocks(strut mount?) under the hood? sway bars are connected under the car connected to?
what does struts do? stiffen up car? less turnning
what do sway bars do???
What is the problem with tie bars? I was about to order a set of bars and was gonna look for a 3 piece set, but since you said that I might only look for a 2pc (front and rear strut) set. Tie bars go underneath the car attatched to the frame in some way right?
