just swapped a JDM h22a into my car and it has a really loud noise in the head
Old Jun 5, 2005 | 03:27 PM
crdcz03's Avatar
Fortune Cookie Member
Default just swapped a JDM h22a into my car and it has a really loud noise in the head
i just finished putting a JDM h22a in my car from hmotorsonline.
it has this really annoying and loud noise coming from the head. i put a screwdriver on the valve cover on top of each pair of intake and exhaust valves and it seems like the noise is coming from cylinder 4 on the intake side.
it might just need a valve adjustment but i figured id ask you guys before i go to work tomorrow and have someone do it for me.
VTEC hits just fine (although i dont do it often just in case this problem is worse than just a valve adjustment lol)
so... without further adoo (sp? i know i got that wrong hahaa)
http://www.we-todd-did-racing....DE%3D
Old Jun 5, 2005 | 04:40 PM
Mikey3000's Avatar
Default Re: just swapped a JDM h22a into my car and it has a really loud noise in the head (crdcz03)
that does sound like it needs a valve adjustment. i would do that and see if it makes a difference.
Old Jun 5, 2005 | 05:21 PM
high_revs's Avatar
try valve adjustment...then go from there.
Old Jun 5, 2005 | 05:55 PM
crdcz03's Avatar
Default Re: (all mOtor h23)
damnit i hate valve adjustments b/c it has to be dead cold for it to be right. meaning ill prolly have to leave it overnight at work
prolly going to do a compression check tomorrow and if thats ok then ill get someone to do a valve adjustment wednesday morning.
and if i have a bent valve do you think hmotors would send me a new head if i sent this one back?
Old Jun 5, 2005 | 09:42 PM
crdcz03's Avatar
Default Re: (crdcz03)
bump before i go to bed
Old Jun 28, 2005 | 01:16 PM
97lude's Avatar
bump, sent you a PM
Old Jun 28, 2005 | 01:36 PM
pentaq's Avatar
Default Re: (97Lude)
HMO is a great company...
We have imported couple engines from them to Europe. No complaints...
Old Jun 28, 2005 | 02:18 PM
staticrex's Avatar
Default Re: (pentaq)
was the water pump replaced before you swapped in the motor?
Old Jun 28, 2005 | 05:15 PM
97lude's Avatar
now im having the same problem... seems to of gotten louder throughout today. just swapped in a h22 from hmotorsonline. replaced the water pump when i swapped in the new motor... going to get a valve adjustment soon and hopefully that will take care of the problem... ugh... just seems to be something new everyday with this damn car
Old Jun 28, 2005 | 07:38 PM
crdcz03's Avatar
i fixed my problem a while ago.
im going to go ahead and tell what my problem was b/c now that its over with i can look back and laugh when i put my cam seals in i never tightened the cam gear bolts thank goodness for the T-belt cover b/c it stopped the botls from backing all the way out
rellikgtx
May 20, 2010 02:11 PM
alx_90ef
Jan 21, 2009 10:42 PM
dc2typer01
Oct 16, 2006 08:55 PM
Bictorious
Apr 24, 2004 07:04 AM
Kango
Jul 27, 2003 11:35 PM
