Fighting my transmission back on! Help!
Ok now, I just replaced my clutch/flywheel, used the alignment tool, and I'm putting the trans back on. Of course it's a PITA to get on, but we finally got the splines to line up. We got it to about 3/8" of being totally on, and it stopped going. So after wrestling with it for an hour, we took a block of wood, and gave a few medium swings with a mallet on the far side of the transmission - the transmission is now mated.
My question is: could I have knocked that bearing out while pounding the transmission on? And if I did, will I know it when I start up the car? How much damage can it do?
TIA
TIA
From: Why so you can pretend like youre interested, FL/OK
The chances are that it is fine. If it was already lined up and in, you just forced it in more. I had the same trouble with mine, but it was more due to the space I had available around me. Instead of banging on mine, I just put all my bolts in and changed between all of them torquing each down to prevent stripping one out. So I basically did the same as you, except I just used the bolts like a fool.
I'm sure if something is wrong you will know it.
thanks for the advice inval
I went with your advice, and my car is running great
Now for the 750 mile break in period :/ UGH
ek4door1987
24
May 9, 2014 07:59 AM
