Need help! 93 Accord EX auto. Swapping in H22A manual. Crank pulley Issue?
Old Jun 5, 2005 | 09:16 AM
akhom's Avatar
Default Need help! 93 Accord EX auto. Swapping in H22A manual. Crank pulley Issue?
Hello,
I have a 93 Accord Coupe Auto.
I'm in the middle of putting in a 92-95 JDM H22A 5 speed.
After putting the motor in the car I have this issue.
The H22A crank pulley sticks so far over it touches the frame rail on the car.
What did you guys do about this?
Did you swap the old F series crank pulley in? ( I notice the F series Pulley is much thinner and should clear. But if I do that the the accessories will not line up? )
If you swap on the F series pulley and use the F series compressor with the H series bracket no problem here right?
Now what about power steering? use the H22A pump and bracket while swapping out the pulley for the old F series one so the ribs on the belts line up?
Mounts I used is Accord drivers mount and bracket.
Rear accord 5 speed mount and bracket.
Front accord 5 speed mount and bracket.
Prelude tranny mount and bracket.
Please help me out.
Thanks
Andy
Old Jun 5, 2005 | 12:57 PM
druciferrr's Avatar
Hmmm, I dunno, but cb7tuner.com specializes in 4th gen accords (which is what you have) and know a lot about that swap, theyd probly know.
skinnyboy
May 27, 2006 08:54 PM
skinnyboy
May 25, 2006 09:44 AM
Joshp14
Jan 12, 2006 09:12 AM
court
Apr 12, 2005 02:52 PM
99lspwr
Feb 25, 2005 03:44 PM
