Check eng light, VTEC no longer working
Old Jun 4, 2005 | 05:51 PM
Cedor's Avatar
Default Check eng light, VTEC no longer working
I was driving and the Yellow check engine light came on, had it checked out the code, dont remember exact number, said VTEC folded. Had him reset it, I was a little low on oil, and hasn't came back on but the VTEC wont kick on when I hit the RPM's. Not sure of what the code meant or what I need to do. Any help would be appreciated.
BTW 98 Prelude sedan no SH
Old Jun 4, 2005 | 06:18 PM
PrettyLude's Avatar
did you make sure the oil level is full? vtec won't work if it doesn't have enough oil
Old Jun 4, 2005 | 06:26 PM
hondalude89's Avatar
Thread is useless with your info. If you gave a code or any other useful information, then you could be led down the correct path on taking care of your problem. Other than that just take it to a mechanic and have them look at it and diagnose it.
Old Jun 4, 2005 | 06:33 PM
Cedor's Avatar
Default Re: Check eng light, VTEC no longer working (Cedor)
The oil level is now full. It still drives perfect but the VTEC wont kick on. I "believe" the code was P 1743 but Im not 100% positive. Just tryin to get some ideas, thanks for the help
Old Jun 4, 2005 | 06:51 PM
lude_behavior's Avatar
Try resetting your ECU and see if the CEL pops on again.
36Chitownrunnin
Jun 17, 2008 08:44 PM
vtec8804
Oct 20, 2006 07:56 AM
greencivic1029
Sep 2, 2005 08:57 AM
kampucheakid
Jun 1, 2005 09:28 PM
vteg
Sep 25, 2002 08:08 PM
