Flow charts of my DIY head from RLZ!
Old Jun 4, 2005 | 04:32 PM
sCeRaXn's Avatar
Honda-Tech Double Platinum Member
Default Flow charts of my DIY head from RLZ!
Some of you may have seen my other post about me porting my head. Heres a link to it in case you missed it https://honda-tech.com/zerothread?id=1265902. Well Brad was nice enough to let me come down there and put it on his Flowbench for no charge earlier today. Let me say...it was awesome to see it done in person. I had no idea that thing was so damn loud...but i guess that has alot to do with my port job. Im still learning though.
Overall i was impressed with what it did. Brad did a calculation and said that i only took off .020 worth of material. Which isnt alot at all. So maybe if i took off a little more material in certain spots(that he recommended) and got a good valve job i could see much better gains. Anyway...here is the chart comparing it to a stock head that he did a valve job and blended the bowl area on. Keep in mind that my head has a stock valve job...well see some soon comparing it to mine with a valve job
I dont think it turned out that bad for a DIY port job with a dremel tool and grinding stones . With proper equipment and a little more practice i hope to be able to produce some nice headwork. OK maybe i need alot more practice
Thanks to Brad at RLZ...he did this for no other reason than to help someone out that was looking to get into the game. There arent alot of people out there that wouldve done it. Hes in it for the love of the sport, which is awesome IMO. to RLZ
Old Jun 4, 2005 | 04:36 PM
Professor15's Avatar
Graphs are a lil bit tiny, there should be more people like brad in this industry...well start practicing on the head lol.
Old Jun 4, 2005 | 04:46 PM
MAX_CFM's Avatar
Default Re: (drchulo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drchulo &raquo;</TD></TR><TR><TD CLASS="quote">Graphs are a lil bit tiny, there should be more people like brad in this industry...well start practicing on the head lol.</TD></TR></TABLE>
lets try this
Old Jun 4, 2005 | 04:47 PM
sCeRaXn's Avatar
I agree.
Im not gonna do too much more to that head except the valve job. But ive got a few others i can practice on
Old Jun 5, 2005 | 06:50 AM
sCeRaXn's Avatar
Default Re: (sCeRaXn)
What happened to all the people who PM'd me asking about the results? Well here they are...enjoy!
Old Jun 5, 2005 | 08:15 AM
b19coupe's Avatar
Looks like a valve job by Brad is better than DIY porting
Curious to see if the chart will look better once you get a valve job.
Old Jun 5, 2005 | 08:50 AM
sCeRaXn's Avatar
Default Re: (b19coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">Looks like a valve job by Brad is better than DIY porting
Curious to see if the chart will look better once you get a valve job.</TD></TR></TABLE>
Yea that was the point of me posting it up. To show just how important a valve job is for flow. I think once i get it done the head will flow much better. And keep in mind that this is an LS head...with porting and a valve job it still wont flow as well as a vtec most likely. But im thinking it will be a nice improvement over stock and will allow the cams to do alot more
Old Jun 5, 2005 | 10:05 AM
MAX_CFM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sCeRaXn &raquo;</TD></TR><TR><TD CLASS="quote">
Yea that was the point of me posting it up. To show just how important a valve job is for flow. I think once i get it done the head will flow much better. And keep in mind that this is an LS head...with porting and a valve job it still wont flow as well as a vtec most likely. But im thinking it will be a nice improvement over stock and will allow the cams to do alot more </TD></TR></TABLE>
I have something good in store ... The valve job on the other head posted was very basic.. I ran some numbers last night with the new valve job I designed
Im thinking we can pull 250 out of our asses if were lucky
Old Jun 5, 2005 | 10:24 AM
hybrid_vtec's Avatar
Default Re: (MAX_CFM)
Good work on your self porting project. Im right behind ya with one of mine. Dont give up b/c you can only get better.
Old Jun 5, 2005 | 10:39 AM
G U E C O's Avatar
Default Re: (hybrid_vtec)
Old Jun 5, 2005 | 10:53 AM
drewzilla's Avatar
Default Re: (stock93cx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MAX_CFM &raquo;</TD></TR><TR><TD CLASS="quote">
Im thinking we can pull 250 out of our asses if were lucky </TD></TR></TABLE>
WOW!!! That would be awesome. We really appreciate you letting us come down there and spending the time to show us everything that you did. Your shop is awesome and we look forward to the next visit
Old Jun 5, 2005 | 11:36 AM
sCeRaXn's Avatar
If we could get it to flow 250cfms id have a heart attack. Thats would be so much higher than my goals .
Is there any way you could calculate how the flow numbers would affect power? Im sure youd have to have other dimensions such as lift/duration on the cams, bore/stroke, compression ratio, etc. but id just like to see how much of a gain i can expect
Also...does anyone know what a stock b16 head flows? I just wanted it to compare the two.
Old Jun 5, 2005 | 12:35 PM
CRVTEC0WNZJ00's Avatar
I'm posting in this to keep updated...this is interesting. I also would like an answer to SCeRaXn's question.
Old Jun 5, 2005 | 12:59 PM
MAX_CFM's Avatar
Default Re: (CRVTEC0WNZJ00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRVTEC0WNZJ00 &raquo;</TD></TR><TR><TD CLASS="quote">I'm posting in this to keep updated...this is interesting. I also would like an answer to SCeRaXn's question.</TD></TR></TABLE>
i dont have a flow sheet @ home but i can over lay a stock B16 head over the LS
charts when i get back to the shop....
Old Jun 5, 2005 | 03:54 PM
sCeRaXn's Avatar
charts when i get back to the shop....</TD></TR></TABLE>
That would be awesome. If i could somehow get it to outflow ANY vtec head id be happy
Old Jun 6, 2005 | 01:10 PM
sCeRaXn's Avatar
I read that a stock LS head flows 206cfm. I havent seen a flow chart but i read it 2 different places. I dont know how acurate it is but im sorta having a hard time believing that our portjob gained 22cfm. If it did then itll make me feel pretty good
Old Jun 6, 2005 | 02:11 PM
MAX_CFM's Avatar
here is your head VRS a stock b16
Old Jun 6, 2005 | 02:34 PM
sCeRaXn's Avatar
Thanks brad. Wow i had no idea a stock b16 head flowed that well . Im trying to figure out how i can use these flow numbers to pick a good cam for my setup. Ill figure it out eventually
Old Jun 6, 2005 | 03:02 PM
JCushing's Avatar
was that pr4 head off a b18a? if so i am pretty sure youd be better off with a b20 or b18b head. the intake ports are bigger...
Old Jun 6, 2005 | 03:08 PM
sCeRaXn's Avatar
Default Re: (JCushing)
Yea its off a b18a. I coulda gotten a b18b head but this one was free so i decided to go with it . Besides...ive always liked trying to do alot with something that isnt supposed to do that much. Which is why i swapped an LS in there in the first place
chad
Jul 7, 2011 09:27 PM
unknown0001
11
May 11, 2007 03:43 PM
JDM turbo DC
Jan 30, 2007 01:31 AM
standbackimapro
Sep 25, 2006 09:47 AM
