JDM H22 need higher then 93 octane?
Old Jun 4, 2005 | 02:24 PM
JDM H22's Avatar
Default JDM H22 need higher then 93 octane?
I have a JDM H22 with 10.6:1 and I always use 93 octane. However, I live in Florida were it is hot and muggy, and It feels like the knock sensor is backing up timming between 3-4K. Now I have read the hesitation threads and I have done everything but change the knock sensor. (no codes). When I put 104 octane boost in the car the engine runs great. Any suggestions?
Old Jun 4, 2005 | 04:24 PM
Pdu-Nz's Avatar
Default Re: JDM H22 need higher then 93 octane? (JDM H22)
JDM should be run on the highest octane you can
Old Jun 4, 2005 | 05:01 PM
LudeBehavi0r's Avatar
Maybe you need new spark plugs...
Old Jun 4, 2005 | 05:33 PM
Shakes's Avatar
space cadet
Default Re: (Ludebehavior85)
there are numerous engines here in cali that run 12:1 + compression on 91 octane. you will be fine.
Old Jun 4, 2005 | 06:19 PM
PrettyLude's Avatar
maybe you just need a tune up
Old Jun 5, 2005 | 07:07 AM
JDM H22's Avatar
Default Re: (PrettyLude)
Brand new denso iridiums, msd wires, 6a BTM, rotor and external coil. The only thing I can think of is to change the knock sensor
Old Jun 5, 2005 | 08:24 AM
did you double check the gap on the plugs?
Old Jun 5, 2005 | 08:34 AM
veganej's Avatar
i have the same problem, or atleast recently, i have new iridiums, gap is correct, timing is good, just a few days ago once i get to about 3k it seems as if its retarding a bit. i used an octane booster to see if it helped and it didnt. but this is the first time ive ran it in the heat.
Old Jun 5, 2005 | 04:34 PM
JDM H22's Avatar
Yeah, they are within spec, and I also had the same problems running the zex plugs. I dont think its the plugs.
Old Jun 5, 2005 | 05:33 PM
Maybe it could be ur fuel filter, since its at higher RPM"s it could be a fuel filter or something.
Or i could just be totallly wrong. IM just tryin to throw some possible ideas out there.
Old Jun 5, 2005 | 05:36 PM
01 LudeDude's Avatar
Default Re: (JDM H22)
From everything I've ever read about "octane boosters" that are all BS. A tank of 93 with a bottle of 108 octane boost will be like 93.8 octane, not even a full point increase.
Old Jun 5, 2005 | 05:49 PM
MackDad's Avatar
Default Re: (01 LudeDude)
I can tell you this much. This weekend up in Gainsville when I took my car on the road course, I put 5 gals of 100 octane in my car (JDM H22A) and it ran as smooth as glass. When I put 93 in on the way home, there was a noticeable increase in engine noise and smoothness. I can also feel the knock sensor compensating for it as well. I'm gonna back my timing down a couple of degrees and see if that helps...
Old Jun 6, 2005 | 07:29 AM
JDM H22's Avatar
98% of the time I would say you are right. However, after reading Super Streets June issue, it shows test on the octane boosters. Most that say "adds 5 points really means you go from 93 to 93.5 like you stated. But testing on the 104 brand they actually saw 3 full points. Also it cleans out injectors and "deposits including those left behind by MMT"
Old Jun 6, 2005 | 08:11 AM
Monkey Fing a Coconut's Avatar
to figure out octane after octane boost, figure 9.5 gal of 91 octane, and .5 gal of 100 octane booster, soo.... .95*91 + .05*100 = 86.45 + 5 = 91.45, sub 104 for 100 if its 104 octane booster, or 117 if you can get xylene from a paint supply store...
jhass
Honda Fit
Jul 27, 2018 08:00 PM
vandersmissenc
18
Nov 10, 2005 10:17 PM
Oct 1, 2003 12:25 AM
wm5holla
Jul 11, 2003 09:34 AM
Piston_Honda
Aug 27, 2001 08:37 PM
