Sign of a bad tranny?
From: Derek Jeter drinks wine coolers,, The Nation, USA
Background on the bike: '03 636 with under 5,000 miles. I have owned it for the last 1500(about 2 months).
Lately between hardshifts I have noticed the shifter rattling, or worse falling a gear lower causing over revs. I realize that this can be common between 1st-2nd just because neutral is there, but this has happened between 3rd-4th at around 100mph in the last week. I tend to ride it like I stole it on a daily basis, but is it common for a tranny to go under 5K miles? Or is it something less severe?
Sup bro, i have an 04 636 and since about 500miles my tranny has acted weird...at first it wouldnt go into gear at times and i'd get a rattling sound and have to pull over and pop it in gear...now at higher rpms when going from 1st to 2nd it won't go past neutral...I think kawis are known for tranny probs..i still love the bike tho!
First off.What oil are you running through it? Always look on the bottle to make sure it's not an "energy conserving oil" before you put it in your bike.Secondly,if you run synthetic too soon there's a slight chance your tranny/clutch could be slipping.Let us know what oil you're using and we'll go from there.
03-04 ZX6R's are known to have sometimes difficult shifts but that is mainly when there is not enough engine rpm/momentum to allow a smooth float from one gear to the next.
I have never heard of them breaking or causing major problems, only being tricky to inexperienced riders (on the bike, not in general).
I switched mine over to Mobil 1 and it has been much smoother since, though I never really had enough of a problem to cause me to mis-shift/overrev, I did have the occasional stiff shift.
Maybe I just got lucky with my bike.
There may be an adjustment necessary on your shifting "star" to realign it if it's misaligned, but thats a tough one to troubleshoot if its only at high rpm's
Do you have the manual on CD or paperback?
I have the CD if you need it.
