Oxygen Sensors Opinions
bosch are ****
oem/denso is the only way you should go
http://www.sparkplugs.com has denso units at great prices
DO NOT buy a bosch
DO NOT buy a bosch
theyre **** because they throw codes for things that arent happening (rich,lean,bad cat)
They dont last
they fall apart
I bought one that didnt last for more than 2months before going bad - others have had similar experiences
They dont last
they fall apart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bmw626 »</TD></TR><TR><TD CLASS="quote">I just called autozone and they said somewhere around $70, thats alot</TD></TR></TABLE>
300$ for an OEM
300$ for an OEM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slow_CvC99 »</TD></TR><TR><TD CLASS="quote">
300$ for an OEM</TD></TR></TABLE>
yup i just came from honda today new 0s sensor is 279$ plus tax...
Bosch's tend to switch more slowly as the ECU is commanding a rich/lean condition and it'll usually lead to an overall rich condition with the ECU sometimes setting a Code 43/45 (whichever is for fuel supply system). So they actually work 'good' for turbo applications or applications where running rich is alright.
But for stock, OEM/Denso.
And $300 for an OEM - is that for the Vx O2 sensor or something? OEM online is like $160 or so.
Well I can assure you that the 02 sensor for the VX is near $300. I bought the Bosh from Autozone and have had no problems with it. Well I seem to have a main relay problem now, but I dont think that the 02 sensor caused that. 13 years and 250K miles can do just about anything to a stock engine.
Here is an ebay ad for Denso O2 sensors for 50 bucks.
http://cgi.ebay.com/ebaymotors...=WDVW
If you guys say these cost $160, is this too good to be true?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CD7power »</TD></TR><TR><TD CLASS="quote">check this place out. http://oxygensensors.com/ </TD></TR></TABLE>
I have a previous thread were I was having problems with an O2 sensor. Checked out http://www.oxygensensors.com and ordered a Denso for I believe 90 bucks.
B, since i have been having o2 issues lately too...ive been looking around and Bosch like ive always said are ****...completey horse ****...Denso OEM fit is the best bet and works well. Ill be replacing mine soon too
+2
got my Walker from there and I now get 32MPG on the highway
+2
i've used/installed more Bosch O2 sensors than i can count.never had a problem out of any of them.on all my own cars i've used them on,i've always gotten above average fuel economy,so no problem there either.
i'm a big fan of OEM parts,so if you can afford it,go with it.as far as just about any other replacement part,i ONLY use OEM stuff.since this isn't a part that could cause huge problems if it failed(like a timing belt for instance),i go with the aftermarket ones.
Chris
Chris
