anyone use nology power core and have problems
Old Jun 4, 2005 | 12:20 PM
freakgolf's Avatar
Default anyone use nology power core and have problems
I just put one on my 00 civic ex and it seems to sputter at low rpm. i did not change spark plugs or wires yet so the plugs could be fouling up do to high volt/amps coming through old ****. anyone else have ploblems. i am also going to get the msd cap with external coil, anyone use that yet (any install tips)
Old Jun 4, 2005 | 12:41 PM
eK9aT10pSi's Avatar
Default Re: anyone use nology power core and have problems (freakgolf)
dont buy ****. buy u a set of NGK blues. never run into any problems with those
Old Jun 4, 2005 | 02:26 PM
Honda.F1's Avatar
I've heard similar stories.
people put on nology wires and have problems
Old Jul 2, 2005 | 02:36 AM
EsQueue's Avatar
Default Re: anyone use nology power core and have problems (Honda.F1)
http://iwcweb.com/eclipse/html/warning.html
Old Jul 5, 2005 | 10:14 AM
builthatch's Avatar
MiG-21 superfan
Freakgolf asked about a Nology PowerCore coil amp, not Nology wires! You guys are replying with opinions on spark plug wires....
The problem you describe is a mystery to me as it relates to the part itself; i used to run a pc10 and also have seen it on many setups with no ill effects...
And to the Nology HotWire haters...go check out Spoon Sports spark plugs wires and you will see why Nology has had to send a cease and desist to Spoon re: their spark plugs wires. Last I checked Spoon doesn't make parts that don't work for their intended purpose...
Steeve_Civic
Jan 6, 2013 12:16 PM
SupraRXZ
Mar 28, 2007 06:33 PM
SlowPokeEg
Mar 27, 2007 08:32 PM
EtchaSketch
Jun 21, 2005 11:42 AM
Charles B.
Nov 2, 2001 03:21 PM
