Throttle body recommendations...
Old Jun 4, 2005 | 11:21 AM
eg8000rpm's Avatar
Default Throttle body recommendations...
Searched:...nada on this/my set-up.
I have a stock block, JDM B16a, and stock JDM B16a head. My Mods in bio ...teh basics
I want to purchase a new intake mani. and I found a good deal on a typhoon im by AEBS w/ 65mm inlet.
What size tb should I go with for this? I was thinking 64mm or should I have it matched to 65mm???
I am also going to p/p the head, dual valve springs /titanium retainers/ 3 angle valve job/ stage 2 cams....in teh future
Or can I just have my stock B16a tb bored to 65mm for this typhoon im?
Old Jun 4, 2005 | 11:45 AM
eg8000rpm's Avatar
Default Re: Throttle body recommendations... (eg8000rpm)
Come on...I see you lookin', but I don't see you replyin'!?!?
bump ttt
Old Jun 4, 2005 | 11:50 AM
b19coupe's Avatar
62mm.
Old Jun 4, 2005 | 12:07 PM
eg8000rpm's Avatar
Default Re: Throttle body recommendations... (b19coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">62mm.</TD></TR></TABLE>
lol, that's what my stock B16a tb is right now right? "What you talkin bout willis?"
Wouldn't that run like **** if the inlet on the new intake mani is 65mm?
*confused*
Old Jun 4, 2005 | 12:20 PM
b19coupe's Avatar
Stock B16 is 58mm, GSR is 60mm, ITR is 62mm. The fact that the inlet is bigger than the bore of the TB is not a big deal.
Old Jun 4, 2005 | 12:24 PM
92 civic VX B18c's Avatar
HT Black Ops
Edlebrock makes a 65mm TB I just picked one up from Jegs ---&gt;http://www.jegs.com/cgi-bin/nc...r=361 for $319 it comes with a TPS and a Gasket, but not MAP.... I bolted it on wednesday night and it works like a champ... I can't wait to see what the actual differance it made on a real dyno, the butt dyno can feel a big differance
Old Jun 4, 2005 | 12:26 PM
JerseySiPOS's Avatar
I would use a 62mm TB also and tune for the most average hp between 6k and 9k. A 65mm throttle body will benefit you the more on your b16 to fill the cylinder above 9000 rpms, IMO. But it varies with each b16 engine combo.
eg8000rpm's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">Stock B16 is 58mm, GSR is 60mm, ITR is 62mm. The fact that the inlet is bigger than the bore of the TB is not a big deal.</TD></TR></TABLE>
So why not go with a 64/65mm over the ITR?
Knowledge is power
Old Jun 4, 2005 | 12:28 PM
eg8000rpm's Avatar
Default Re: Throttle body recommendations... (JerseySiPOS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JerseySiPOS &raquo;</TD></TR><TR><TD CLASS="quote">I would use a 62mm TB also and tune for the most average hp between 6k and 9k. A 65mm throttle body will benefit you the more on your b16 to fill the cylinder above 9000 rpms, IMO. But it varies with each b16 engine combo.</TD></TR></TABLE>
So I should only go bigger than 62mm if I'm revvin past 9k?
Old Jun 4, 2005 | 12:46 PM
eg8000rpm's Avatar
ttt
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg8000rpm &raquo;</TD></TR><TR><TD CLASS="quote">
Knowledge is power </TD></TR></TABLE>
I hear ya. I tried a stock 60mm TB, a 62mm TB/ITR manifold combo, and a bored ITR 70-65mm TB with aebs manifold on a cammed b16. I just compared how big you need to go in relation to engine speeds. I peaked over 800 rpms higher, with a 70-65mm ITR tb/aebs mani compared to a stock ITR TB/mani combo, but didn't make any more tq or even peak power with the bigger inlet. Your cam profile, header, and tuning affects where the motor will breathe the best.
Personally, i would rev a b16 with a combo where it breathes better...at higher engine speeds.
Old Jun 4, 2005 | 12:56 PM
eg8000rpm's Avatar
Thanks for info bro
I think I'll be going with the 62mm tb. That gives me +4mm over my stock B16 tb, so with some good tuning and the new im, I should see some decent gains...and when I get my head work done all the better
More info still welcome, would still like to know of all ya set-ups on the im/tb combos and what gains at what rpms you guys are gettin'. Pros and cons
Old Jun 4, 2005 | 01:42 PM
no problem. my stock B16 throttle body off my 2000 Si was 60mm on the throttle plate side. the first gen b16's have a 58mm.
Start off with the 62mm TB and work your way up as trial and error.
Old Jun 4, 2005 | 05:09 PM
eg8000rpm's Avatar
Start off with the 62mm TB and work your way up as trial and error.</TD></TR></TABLE>
Yeah I can always bore it if I need some more uummph later on after cams and head work
Old Jun 4, 2005 | 10:14 PM
VSBB6's Avatar
I have a Spoon 70mm TB for sale, IM me if you're interested.
Old Jun 5, 2005 | 11:03 AM
DelSolDon's Avatar
Default Re: Throttle body recommendations... (VSBB6)
yea, the first gen (cable trans.) B16's have the 58mm, the other B16's have 60mm. just send your TB to maxbore for $100 and he will do what you want. usually cheaper than an ITR TB.
Old Jun 5, 2005 | 02:31 PM
RedEj8's Avatar
Theres a guy on here in the classifieds that can bore ur stock b16 tb to 64 all the way thru and make a new throttle plate all for like 100 bucks.I'll probably be doin that
Old Jun 5, 2005 | 03:00 PM
DelSolDon's Avatar
Default Re: Throttle body recommendations... (reddohcvtec)
yea, maxbore.com, same guy i was referring to
junkyard racer
Dec 1, 2006 03:52 AM
eg8000rpm
Feb 4, 2006 06:39 PM
Got Milk
21
Dec 28, 2004 01:05 PM
mellowboy
May 11, 2003 05:43 AM
