B16A3 Del Sol Injectors fit D16Y8 Civic?
Old Jun 4, 2005 | 09:11 AM
Hatch_Back_97's Avatar
Default B16A3 Del Sol Injectors fit D16Y8 Civic?
I really need an answer in less then 4 hours for I am going to buy some injectors to upgrade mine. I was told that the D16Y8 uses 240cc injectors and I foudn a set of B16A3 injectors for cheap and I really need to upgrade for my mods plus soon I will turbo. Help!
Old Jun 4, 2005 | 09:19 AM
_gurusan_'s Avatar
Default Re: B16A3 Del Sol Injectors fit D16Y8 Civic? (Hatch_Back_97)
b16a3 injectors are OBD-1, so you'll need the OBD-1 injector clips.
However, there's no point whatsoever because b16 injectors are 240cc also.
What mods do you have? 240cc is good for at least 170 whp.....
If you plan on going turbo then you'll need MUCH bigger injectors like 450cc
Old Jun 4, 2005 | 09:22 AM
menkio's Avatar
what mods do you have.. ?
Old Jun 4, 2005 | 09:45 AM
Default Re: B16A3 Del Sol Injectors fit D16Y8 Civic? (menkio)
Full cat back but theres no cat, just straight piping 2 1/4"
Holley 4 into 1 race headers
MSD SCI Ignition setup
Nology Power Coil
Nology Hotwires
Silverstone plugs
Front mount cold air intake
Old Jun 4, 2005 | 09:46 AM
_gurusan_'s Avatar
theres no way you don't need new injectors for those mods.
Old Jun 4, 2005 | 02:52 PM
built562's Avatar
Default Re: B16A3 Del Sol Injectors fit D16Y8 Civic? (_gurusan_)
no need for larger injectors
plus b and d series injectors flow the same. 240. please research. plus they are obd I.
Old Jun 4, 2005 | 02:53 PM
jlacoy82's Avatar
71.192.16.183
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _gurusan_ &raquo;</TD></TR><TR><TD CLASS="quote">theres no way you don't need new injectors for those mods.
You obviously meant to say, "Theres no way in hell with those mods that you need bigger injectors, the ones you have are fine already."
Old Jun 4, 2005 | 03:38 PM
_gurusan_'s Avatar
Default Re: B16A3 Del Sol Injectors fit D16Y8 Civic? (jlacoy82)
lol yeah I said the opposite of what I meant.
d16racer
Sep 22, 2006 07:33 PM
c1v1c_R
May 1, 2004 07:26 PM
evo
Mar 16, 2003 05:43 AM
