B16A3 Del Sol Injectors fit D16Y8 Civic?
I really need an answer in less then 4 hours for I am going to buy some injectors to upgrade mine. I was told that the D16Y8 uses 240cc injectors and I foudn a set of B16A3 injectors for cheap and I really need to upgrade for my mods plus soon I will turbo. Help!
Re: B16A3 Del Sol Injectors fit D16Y8 Civic? (Hatch_Back_97)
b16a3 injectors are OBD-1, so you'll need the OBD-1 injector clips.
However, there's no point whatsoever because b16 injectors are 240cc also.
What mods do you have? 240cc is good for at least 170 whp.....
If you plan on going turbo then you'll need MUCH bigger injectors like 450cc
Re: B16A3 Del Sol Injectors fit D16Y8 Civic? (menkio)
Full cat back but theres no cat, just straight piping 2 1/4"
Holley 4 into 1 race headers
MSD SCI Ignition setup
Nology Power Coil
Nology Hotwires
Silverstone plugs
Front mount cold air intake
Nology Power Coil
Nology Hotwires
Silverstone plugs
Re: B16A3 Del Sol Injectors fit D16Y8 Civic? (_gurusan_)
no need for larger injectors
plus b and d series injectors flow the same. 240. please research. plus they are obd I.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _gurusan_ »</TD></TR><TR><TD CLASS="quote">theres no way you don't need new injectors for those mods.
You obviously meant to say, "Theres no way in hell with those mods that you need bigger injectors, the ones you have are fine already."
