Keyless Ignition system
Alright guys last summer I made up a system to completely remove the key switch from my car and replace it with a key code entry system.
Unfortuntently in this case I Drive a Del Sol and there's no cosmeticly pleasing place to mount the keypad to my satisfaction. So I was wondering if anyone else would like the design for it? I was thinking about making the units and it would work off of a alarm system tho not a key pad for cost reasons altho if you got your own keypad system I could tell you how to hook it up very easily.
I was thinking around $100 for the harness (parts cost close to that), it would work off of a alarm system not the keypad tho, but could easily be wired to said system. Also it could be used solely for the ignition system if you want to keep your key switch.
Edit:
I am going to post the diagram later, but was wondering if people would be interested in purchasing the kit at all.
Modified by nocturnaldragon at 11:17 AM 6/4/2005
Edit:
why dont you just post up a how to and help out your fellow honda finatics. i for one wouldnt do it but if i was smart enough to know how i would post it up. but if you need money i understand that too.
I really dont, and will end up doing that eventually Im more or less interested in knowing if people would be interested in purchasing a kit.
What really happens with the keypad? When you enter the correct keycode, you are then allowed to start the car via S2K style push-button? What starts the car?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nocturnaldragon »</TD></TR><TR><TD CLASS="quote">I am going to post the diagram later, but was wondering if people would be interested in purchasing the kit at all.</TD></TR></TABLE>
You'll probably get a better response after posting the schematic. What's this harness you speak of - what does it consist of? Post up some more info so we can see how fitting $100 is.
Sorry, yea that is a good point,
Basicly the heart of the system is a latching relay, which in turn operates a few other relays, The latching relay is ussed because only a pulse is ussed to trigger it one way or the other not a constant voltage. Once the system is armed or turned on yes a push button would be ussed for the start system
Im going to have to make the diagram up later tonight on viso. I dont think im going to make harness tho Ill just post how to do it yourself.
Golferdude1977
Sep 17, 2005 06:56 PM
