rad fluid bottle
okay, i have a 96 accord
just need to confirm with other people on the site
if you check the rad fluid bottle, when you open the lid, is there a rubber hose/tube that hangs off of it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by devilpuppy »</TD></TR><TR><TD CLASS="quote">okay, i have a 96 accord
if you check the rad fluid bottle, when you open the lid, is there a rubber hose/tube that hangs off of it?</TD></TR></TABLE>
Yea there is, this hose basically dumps the excess runoff of coolant from the radiator into this little reservoir.
that's 1/2 of it...
when you shut down, the coolant contracts, the vacuum valve of the rad cap opens, & u either suck in the resevoir fluid (if the hose is there) or u will suck in some air instead. if u open the rad cap & see that the level of coolant is kinda low when it's cold, put a hose back on the resevoir cap to reach the bottom of the plastic bottle. Air pockets in the coolant system is teh sux.
think of a straw in a glass... lift it above the fluid level & suck...then lower the straw down near the bottom...booyah!
ck123
Jul 21, 2006 08:33 PM
