"pre-building" and throttle bodies
I just swapped a B16 into my Sol and eventually would like to boost her. In the meantime I want to overbuild everything, i.e. new radiator, ignition?, wideband and so on. I will get the bigger injectors needed as well, just not install them yet. Is a larger throttle body needed for ~250-300hp? I thought I'd do that too now because it's an easy bolt on, but I have read that too large a TB on a mostly stock motor would hamper it some. Mininmal gains are fine if it will help later under boost but I don't want to lose anything.
ssr_h22
Apr 23, 2005 07:53 AM
