b16 sir II into a 97 ek help!
ok i put a obd 1 sir 2 b16 swap into an ek and wired everything up correctly ... but the car still runs like **** .. i am using an obd 1 p30 computer.. when you give gas the engine seems like it isnt advancing the timing and it is running real rich ... i changed the dizzy and still the same **** ... anyone ever have this problem ? help me out guyz
Thanks
Joe
Thanks
Joe
Give her the usual line up of "problem revealing" procedures:
Check the compression
Check the injectors
Check the plugs
Check the FPR
Check the engine/tranny grounds
Check pretty much anything else that doesn't cost money to check.
Then report back.
Check the injectors
Check the plugs
Check the FPR
Then report back.
davey421
15
Jan 23, 2009 08:06 AM
B18C GSR CIVIC
10
Sep 25, 2006 06:12 PM
tommyj
Nov 12, 2005 10:02 PM
