trubo set up
Old Jun 3, 2005 | 08:54 PM
Lude454's Avatar
Default trubo set up
what do i need to buy to do a trubo setup
i have a 2000 prelude sh and i have a cat back and intake and shocks/ lowering springs
i need to know what ecu upgrade i need to get remember i have a sh and hondadata won't work and i what to run at least 15 psi on the street and i know i have to build the engine i just need a complete list on what i will need.
thanks
john
Old Jun 3, 2005 | 09:03 PM
LostAndFound's Avatar
Default Re: trubo set up (Lude454)
this has really been covered extensively.
your going to ditch that intake you have too.
rebuild your engine is going to start with it getting resleeved and forged parts, at least pistons.
need to tune, manifold, turbo, waste gate, bov,downpipe, injectors, fuel pump, intercooler, IC piping to list a few. search it, it just takes a few minutes to find it all out.
Old Jun 3, 2005 | 09:22 PM
AndyD's Avatar
I would buy pullies, a Type R shift boot, some rimZ, K&N air filter, and a DC Sports header.
You should be able to boost up to 15lbs then.
Old Jun 3, 2005 | 11:46 PM
deca's Avatar
Default Re: trubo set up (AndyD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndyD &raquo;</TD></TR><TR><TD CLASS="quote">I would buy pullies, a Type R shift boot, some rimZ, K&N air filter, and a DC Sports header.
You should be able to boost up to 15lbs then.</TD></TR></TABLE>
and u also need a boost controller so u can turn up the boost while runnung the dc header
Dasfinc
Jun 23, 2008 09:23 AM
tig3rxiong
Oct 21, 2004 07:23 PM
cyrock
May 20, 2004 11:57 AM
sidan
Jan 7, 2004 07:24 PM
1hotvtec
Jun 10, 2003 11:25 PM
