head gasket oil leak
Old Jun 3, 2005 | 04:43 PM
BB6racer's Avatar
Default head gasket oil leak
first off i have a 5th gen base model. so i was driving to work a couple days ago after doing a valve adjustment, and my oil light came on. i looked under the hood and there was oil all over the cam gear side of the motor. i got it back home and found the valve cover gasket had not settled right. so i put it in right and added oil, but it still leaked oil. i put some liquid gasket on, but that still didn't do anything. did i break something driving to work? do i need a new gasket? will i need a new timing belt, since its been exposed to oil? thanks for any help.
Old Jun 28, 2005 | 04:42 PM
Toxidomask's Avatar
Default Re: head gasket oil leak (BB6racer)
maybe the seals for the distributor or the seal for the exhaust cam plugs. try looking around those area and replace if leaking.
Old Jun 28, 2005 | 04:56 PM
PrettyLude's Avatar
carb cleaner and brake cleaner is ur friend, clean all that oil off first and then see where's it coming from
kaivorth
Honda Civic (2001 - 2005)
Oct 31, 2016 07:02 AM
big-cat
Aug 8, 2009 05:05 AM
EkFG
Mar 15, 2008 07:47 PM
Kapetan
Oct 19, 2006 08:35 AM
spender1326
Jun 24, 2005 06:41 PM
