starter question.
Old Jun 3, 2005 | 03:37 PM
d16efsedan's Avatar
Default starter question.
well earlier today my starter signal wire broke*shitty place racing harness*so we wired it back together for now,it started up a few times then wouldnt.i think the starter went out but just wanted some opinions.when i go to start it up it just clicks doesnt do nothing else...TIA
Old Jun 3, 2005 | 04:06 PM
boostedSI90hatch's Avatar
Banned
Default Re: starter question. (d16efhatch)
bad ground or you fried it
Old Jun 3, 2005 | 04:48 PM
Kwicko's Avatar
Default Re: starter question. (nice_b18a_hatch)
Try hotwiring it. Get a little jumper wire with an alligator clip on one end, clip that to the starter where the little spade connector goes (small black wire); touch the other end to the positive battery cable and see if it cranks. Oh yeah - and be sure it's in neutral!
I just went through having my '91 CRX DX not start on me. Same kind of symptoms - I got the "click" when I hit the start position on the ignition, but no starter. I hotwired it, it started right up, so I knew the starter was good. Turned out to be the little clutch-interlock switch on the clutch pedal arm - it crumbled apart, so the clutch couldn't give the signal that the clutch was pushed in; hence, no start.
Mike
slowassBubble
May 15, 2011 07:50 AM
twentyhurtz
Dec 14, 2009 12:28 PM
TeggieeTuner
Jul 20, 2008 04:29 PM
bayoufrogg
Oct 24, 2006 08:18 PM
Bbasso
Apr 6, 2003 12:02 PM
