Help on motor build
I'm running a jdm B16 right now with IHE, head has port work, valve job and a wal 255FP. trying to make up my mind on what parts should get or go with to achieve 200 + whp tuned. want to stay around 12.8:1. I have a ls bottom end. I have about 1300 buck to play around with for now hope to have a little more cache in a month or so. like to get started asap on the project. want to run it in about a month in wendover.
Modified by spockeg at 2:47 PM 6/3/2005
Stock GSR block
LS crank
Eagle Rods
SRP pistons (zero deck, .040" cometic gasket, approx. 11.98:1 compression)
Fresh OEM honda bearings, oil pump, water pump
Stock ITR head portmatched to victorX intake, 5 angle valve job, lightly ported exhaust
VictorX intake mani, stock TB opened up a bit
Blox B cams, Crower springs/retainers
Weapon-R Race Header
2.5" catback with ES oval
450CC DSM's, walbro 255, uberdata
The injectors are so big because they're from my turbo car when it wasn't so fast. In a 2200 pound car it'll keep up with a stock LS1 F-body and they trap right around 107, so it's moderately quick. You obviously don't need the pistons or rods, but I got both in a package deal for cheap so I went for it.
LS crank
Eagle Rods
http://home.broadpark.no/~tfor...l.wmv
how to build 200whp b16. its about 45 mins long
i haven't seen the whole vid yet, i just found it off another board
watch this video you *******
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ReddragonDC2 »</TD></TR><TR><TD CLASS="quote">http://home.broadpark.no/~tfor...l.wmv
this b16 is stock bore/stroke, 11.7 cr (i think), rm m22 cams, hytech header, 2.5" exhaust
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mohsin »</TD></TR><TR><TD CLASS="quote">11.7 CR on stock bore? What about pistons?</TD></TR></TABLE>
probably p30's because the head was milled quite a bit
96ekb20
Sep 16, 2016 03:17 PM
