Fan won't work unless....
Hey,
Newbie here. My question is... that on my 91 accord, both my fans will only come on when the A/C is turn on. My fan will not turn on even if the car hits that certain temperature for it come on. But yet when i turn on the A/C both of them comes on. What do you think is the issue here? How can I solve this? Well let me know.
assuming there is planty of coolant in radiator and your thermostat is working ok and not stuck closed.. it could be the fan switch located on t-stat housing, left side of distributor, unplug and bypass it ..if fans come on that is your problem make sure to do this test when car is warmed up to verify problem
