im doing a cam install i have ?s
Old Jun 2, 2005 | 10:20 PM
sohctodohc's Avatar
Default im doing a cam install i have ?s
i searched and didnt find what i wanted. as much as i would love to dyno tune my car the nearest place is 3 hours away keep that in mind.
so what did most ppl go with on the cam gear timing with this cam??? i am buying the valve springs with this just for safety. my ? on these is do they wear fast? and i am not planning on changing stock rev limit so do i need the retainers or no??? i heard stock ones dont wear as fast as the titanium ones. and with the
aem cam gear has neone had problems with it??? it has a 5 bolt pattern so i figure it would be ok, thanks for the help
Old Jun 2, 2005 | 10:27 PM
skip.two's Avatar
Default Re: im doing a cam install i have ?s (sohctodohc)
um you never mentioned what cam and cam gear you're talking about...
SOHC cam? Comp/Zex 59300 cam? PM Soccerking3000
Old Jun 2, 2005 | 10:31 PM
sohctodohc's Avatar
Default Re: im doing a cam install i have ?s (skip.two)
yea wow sorry im tired its the 59300 ca, and aem cam gear
Old Jun 2, 2005 | 10:47 PM
sohctodohc's Avatar
i still need help with the springs and cam gear. i know most ppl say stock is fine till after stock limit but im not taking any chances is it stoooopid to do with out retainers??? anyone happy with the aem cam gear or had problems.
Old Jun 3, 2005 | 08:03 AM
3lue_by_u's Avatar
IMO it would be stupid to have everything out and not do springs and retainers. I just did my cam and cam gear and springs and retainers and I have no complaints.
Old Jun 3, 2005 | 10:15 AM
sohctodohc's Avatar
Default Re: im doing a cam install i have ?s (3lue_by_u)
i plan on doing the springs but i dont know bout the retainers i heard the stock ones are fine. if not better????
Old Jun 3, 2005 | 10:18 AM
sohcvtec1995's Avatar
I would just do it all while you have it apart. Hell, i would slap a new Head gasket on there aswell, just to get it out of the way.
Old Jun 3, 2005 | 11:39 PM
sohctodohc's Avatar
Default Re: im doing a cam install i have ?s (sohcvtec1995)
i talked to soccer king and he is forced inducted so the timing is way diff. so if theres nebody else out there thats chip in please
Old Jun 4, 2005 | 08:15 AM
3lue_by_u's Avatar
I am not forced induction yet....... And I have the same cam. I would do springs and retainers while you have it apart it is not that hard at all to do. I had mine done in 2 hours. And that was setting all of the valve lashes. You dont have to take the head off so I don't see why you would change the head gasket. Unless you feel like it. I would just save yourself the hassle and do it now instead of later. You are going to have to have the retainers out to change the springs anyway so what would it hurt to drop in some Ti ones? My AIM is joshluvsali if you need any help.
Old Jun 5, 2005 | 09:34 AM
sohctodohc's Avatar
ok once again no one has answered my ? the ti retainers have to usually be replaced 15000 miles right? but the springs dont have to be replaced like the ti retainers.
Old Jun 5, 2005 | 10:16 AM
inane's Avatar
did you pick the cam based on what YOU wanted out of the engine? cams change the entire behavior of the engine... how high they lift, how long they stay open... you have to consider the shape of the lobe too... if its too cone shaped, youll want a flat rocker and if its more smooth youll want a roller rocker... a roller may jump... theres a lot to take into consideration when changing the cam and cam gear... cams can adjust the powerband and when it kicks in... although on a honda anything can be done to really make more power... just cause they dont have any power to begin with
Old Jun 5, 2005 | 07:47 PM
sohctodohc's Avatar
Default Re: im doing a cam install i have ?s (inane)
yea i have read alot into it and this is the one i have decided to go with
Mr_Bojangles
Apr 15, 2004 06:15 PM
South Bay Surfer
15
Mar 29, 2003 06:17 AM
DaNish
Nov 9, 2001 08:52 PM
