compression tested, does #'s look good.
ls/vtec
-pr3 head (not milled)
-arias 11.0:1 piston
-eagle rods
-stock crank
-stock head gasket
compression ratio is calculated at 11.6 or 11.7:1
did a compression test after about 35k of driving and results were:
#1 cyl - 235 psi
#2 cyl - 230 psi
#3 cyl - 230 psi
#4 cyl - 230 psi
just wanted to know if that is where it is suppose to be or is it low for the setup. cause i didn't do a compression test when i first had it built and ii don't know anyone who has the same setup and has done a compression test to compare #'s.
-eagle rods
-stock crank
-stock head gasket
#1 cyl - 235 psi
#2 cyl - 230 psi
#3 cyl - 230 psi
#4 cyl - 230 psi
they can, but only if they have a lot of overlap. at low rpms you lose a lot of compression due to the intake and exhaust valve being open together on the compression stroke. on my old dumbestic race car i was running 13:1 compression but with a cam that had 280 degrees of duration intake and exhaust so i had like 60 something degrees of overlap. during a compression test i was lucky to make 180psi, lol. i had to set my idle at 2500rpm just to get a decent vacuum.
Well he has a b18c block with 11.5-.7 compression, stock 2000 si head, stock cams, skunk2 manifold, and a jdm 4-1 type r header. He made 176 hp and 126 ft lbs of torque on fastrip 91 octane. This was on a dyno jet and it was tuned with hondata. He is hoping to hit the 200 mark with cams and headwork.
i just did a quick description on my motor in the begining. my setup is:
-pr3 mild port with 3 angle valve job
-complete crower valve train
-ctr cams
-itr manifold
-98 lude injectors(290cc)
-ls block w/ arais 11.0:1 on eagle rods, gsr girdle
-gsr tranny
-arp head studs
just chipped p28 rite now untuned. waiting on the dyno anytime soon hoping for at least 190 whp on hondata.
-ctr cams
-itr manifold
-gsr tranny
-arp head studs
