Modification to valve guides necessary for crower nonvtec 403's ?
Old Jun 2, 2005 | 09:02 PM
HondaGuy02's Avatar
Banned
Default Modification to valve guides necessary for crower nonvtec 403's ?
ok, ill start with the set up specifications....
- LS b18b1 obd1 head
- factory valve guides (never changed out)
- pretty extensive port and polish (valve guides were shaved down flush with head, only on the bottom side of the valve guide, didnt touch anywhere else)
- crower nonvtec cams (403's aka stage 2's)
- crower springs (street/strip) orange springs
- factory retinners
- factory valves
Now when i tryed running the motor for the first time, wouldnt start. I had almost no compression and had snapped piston rings and had piston slap and full nine. So anyway, back to the point of this thread in the first place. I took the Head off of the motor and it turns out my valve guides were pushed down a good quarter of an inch and i know this because when i was doing the porting and shaved them down myself almost flush. I relise that the valve guides being pushed down could of happen for a few different reasons but... what i want to know is, should i have modified the valve guides because of the lift on the cams being so high or can you run the crower 403's on a 100% factory head ?
Im aware that its a common thing to shave down or modify valve guides according to your cam profile but is it necessary for this set up, i didnt think it was but correct me if im wrong people...????
Old Jun 3, 2005 | 02:35 AM
non-VTEC's Avatar
Default Re: Modification to valve guides necessary for crower nonvtec 403's ? (HondaGuy02)
that is very un common to happen. there is no need for valve guide modifications for those cams.
did you do a proper valve adjustment when installing the cams?
the 403's dont have THAT much more lift than the stock cams. sounds like you had a bad valve adjustment.
Old Jun 3, 2005 | 08:19 PM
HondaGuy02's Avatar
Banned
Default Re: Modification to valve guides necessary for crower nonvtec 403's ? (non-VTEC)
thats what i fegured, i had a buddy of mine try adjusting the valves, he used a feeler gauge. He had the feeler gauge at .006 thousanths and .008 thousanths < which i was told is WAAAY to tight and thats why the valve guides were impacted..... ???
Old Jun 4, 2005 | 12:34 AM
StorminMatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaGuy02 &raquo;</TD></TR><TR><TD CLASS="quote">thats what i fegured, i had a buddy of mine try adjusting the valves, he used a feeler gauge. He had the feeler gauge at .006 thousanths and .008 thousanths &lt; which i was told is WAAAY to tight and thats why the valve guides were impacted..... ???
A couple of thousandths of an inch difference is not going to cause this sort of problem.
Old Jun 4, 2005 | 09:08 AM
HondaGuy02's Avatar
Banned
Default Re: Modification to valve guides necessary for crower nonvtec 403's ? (StorminMatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt &raquo;</TD></TR><TR><TD CLASS="quote">A couple of thousandths of an inch difference is not going to cause this sort of problem.</TD></TR></TABLE>
well, see what i was trying to say is.. i think there are 2 different ways of measuring with a feeler gauge, i think it has something to do with measuring in metric or standard... i was suppose to measure one way and my buddy measured the other way (the wrong way, the much tighter way) and thats why i think my valves were adjusted too tight....
can someone help us out here.. proper valve adjustment specs????
Old Jul 10, 2005 | 07:37 PM
BLUE EH3's Avatar
Help we my pennies
who sell crowers?
narfdanarf
19
Nov 3, 2010 10:07 PM
b16a27
Oct 28, 2008 08:26 PM
HondaGuy02
Jun 2, 2005 06:27 PM
