Throwing Code 7
Old Jun 2, 2005 | 09:00 PM
HatchMo's Avatar
Default Throwing Code 7
I have a 91 hatch w/ y8 swap with stock si ecu. Anyways the past couple of days a CEL (code 7) will come on then when the car is turned off and back on it goes away. I checked the code its for Throtle position sensor (tps). I was wondering how to fix this?
Tia, ben
Old Jun 3, 2005 | 06:09 PM
HatchMo's Avatar
Default Re: Throwing Code 7 (HatchMo)
come on people?
Old Jun 3, 2005 | 06:21 PM
Mach69's Avatar
I am in the same boat as you, I got a code 7. Also make sure the connectors at the ecu are good. Pretty easy fix. It can only be a few things. 1. The tps itself. 2. One of the three wires is not continuous. 3. Bad connection somewhere. 4. or somehow your ecu is screwed up.
Here is what the manual says to do:
Page 1: http://www.we-todd-did-racing....3D%3D
Page 2: http://www.we-todd-did-racing....3D%3D
Old Jun 8, 2005 | 09:48 PM
HatchMo's Avatar
Default Re: Throwing Code 7 (Mach69)
thanks man going to check everything out tomorrow.
ben-
new_climber
Sep 17, 2009 08:26 AM
maximedx
May 30, 2002 01:41 PM
Evil DOHC
Jul 30, 2001 11:01 AM
