jdm eg9 cluster
Old Jun 2, 2005 | 06:15 PM
vtec94civic's Avatar
Default jdm eg9 cluster
hey i just installed my eg9 cluster, but when i put the key in the second position the tachometer jumps to 1500 rpm and when i start it it idles at 3000rpm but my vafc only says 850rpm at idle. i need help thanks.
Old Jun 2, 2005 | 07:55 PM
neutron91's Avatar
Default Re: jdm eg9 cluster (vtec94civic)
im guessing the needle will need to be taken off and moved to attain the correct idle
Old Jun 3, 2005 | 05:06 AM
i don't think that will fix the problem. there must be some wiring that needs to be changed around. if i reposition the needle it will still be off because the needle jumps up to 1500 rpm when i turn the key and stays there then when i turn the car on it goes to 3k.
Old Jun 3, 2005 | 08:23 AM
clint g's Avatar
this is a dousy try gettin the mod with the red 4dr (cant remember which one ) to chime in some help
jackp0t
Jul 15, 2011 04:08 AM
JDM_rolex
Mar 7, 2011 07:17 AM
