Suspension & Brakes Theory, alignment, spring rates....
Horrible Squeeksss and clanks. 1995 Prelude KYB AGX
Old Jun 2, 2005 | 06:14 PM
DarkBB4's Avatar
Default Horrible Squeeksss and clanks. 1995 Prelude KYB AGX
I have basically brand new kyb agx suspension in the lude (5k miles or less) and ive always had some little suspension noise, but after removing my strut bar, and back seats... there is no SOUND barrier at all... and the squeeks are realllly loud now.
Like... They are unbearable.
Over every little bump they SCREEEAM at me, there is not way to avoid it. I lifted the car up in the air ,and u can press up on the wheel. At the top of its stroke (or as hard as i could push without it flipping ) it squeeks.... Ive sprayed tons of WD-40 and white lithium grease, but no luck at solving this..
I also looked into removing the top bolt and grinding down/cleaning up the metal collar that is in there... This stil does not solve this!
Problem solver?
Now, the one thing i can think of is the springs are fkd up. THey are older and have some corrosiion/rust and what not....
what else could it be, im tryin to save my eardrums, a couple $$ and as much time as possible
THANKS
Old Jun 2, 2005 | 08:12 PM
EK k kay's Avatar
Default Re: Horrible Squeeksss and clanks. 1995 Prelude KYB AGX (DarkBB4)
Try using different springs. Are you running polyurethane bushings?
Old Jun 3, 2005 | 02:58 AM
DarkBB4's Avatar
Default Re: Horrible Squeeksss and clanks. 1995 Prelude KYB AGX (chowmien)
i wll, how hard of a job is that... it seems easy becuase when i lift the car up,the springs are basically loose.... and i can just spin them around!
cani just use any llowering springs (i want to go lower in the back anywyas)
i think its juts stock bushings
Old Jun 5, 2005 | 05:07 PM
DarkBB4's Avatar
Old Jun 5, 2005 | 05:41 PM
LudeBehavi0r's Avatar
.....I dont think ur supposed to be able to spin ur springs around between the purches even when the car is in the air. Try tightening (sp) the spring perches.
Old Jun 5, 2005 | 05:50 PM
DarkBB4's Avatar
Default Re: (Ludebehavior85)
pics?
is that the bolt in the trunk?
Old Jun 6, 2005 | 05:25 AM
DarkBB4's Avatar
Default Re: (DarkBB4)
ttt
nonpareil
Suspension & Brakes
Oct 13, 2009 06:16 PM
DarkBB4
Suspension & Brakes
Jan 8, 2007 09:29 PM
Neo858
Aug 2, 2006 05:02 PM
exr_pd
Aug 22, 2003 05:13 AM
Peter K
Oct 2, 2002 07:26 PM
