a6 block y8 head need help vtec wont hit on no cel?
Old Jun 2, 2005 | 04:19 PM
jdmexsi's Avatar
Default a6 block y8 head need help vtec wont hit on no cel?
I heard that the a6 block has a weak oil pump and i would need to change it if i wanted to have vtec. If true what pump do i use a 1.6 or 1.5? I have no cel on a chipped p28. The head has a skunk 2 stage 2 cam, skunk deuce intake manifold, port and polish it should scream but it's a turd! Vtec solinoid clicks on straight power but not on a button. How do i check if head or solenoid has enough oil pressure!!!! Help it's driving me insane!!!!
Old Jun 2, 2005 | 04:26 PM
eg4door's Avatar
Default Re: a6 block y8 head need help vtec wont hit on no cel? (jdmexsi)
Did you pull the little oil jet valve out of the block? If you didn't thats your problem.
Old Sep 25, 2005 | 10:52 PM
julio_bOostamante's Avatar
I'm a Jackass
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmexsi &raquo;</TD></TR><TR><TD CLASS="quote">I heard that the a6 block has a weak oil pump and i would need to change it if i wanted to have vtec. If true what pump do i use a 1.6 or 1.5? I have no cel on a chipped p28. The head has a skunk 2 stage 2 cam, skunk deuce intake manifold, port and polish it should scream but it's a turd! Vtec solinoid clicks on straight power but not on a button. How do i check if head or solenoid has enough oil pressure!!!! Help it's driving me insane!!!!</TD></TR></TABLE>
i ahave never heard of the A6 pump being weak for this set up. can anyopne verify this?
HondaDOHCsi
Apr 14, 2016 05:47 PM
helpmeplease
Feb 19, 2011 07:17 AM
SHG_Beans
Nov 15, 2005 06:16 PM
egizzle8
May 25, 2005 07:39 PM
