Jdm cluster ????
Old Jun 2, 2005 | 01:44 PM
acura69gsr's Avatar
Default Jdm cluster ????
k guys a buddy of mine hooked me up with a jdm cluster i put it in my 01 itr and the km and tach work fine but the gas and temp don't work at all and when i use a trun sig. the speedo and tach jump up and down? he said that he was told that this was b/c the wire pins on the cluster where for a older car like 95-97 something like that is that true.
so if i get a newer one will it plug and play right?
i saw a guy has a eudm out of an 00 itr would that work right?
please do not put wrong form or use search, i like the itr form and i did try a search didn't find my ?
Old Jun 2, 2005 | 03:31 PM
JDM Factor's Avatar
Yeah when I got my spoon cluster I had the same problem. I took the circuit board piece off the spoon cluster and put my usdm one on.
Old Jun 2, 2005 | 04:20 PM
ALLphilthyDC2's Avatar
Default Re: (JDM Factor)
i have a similar problem, my gas gauge doesn't work at all, my temp works fine, but the seatbelt light is always on... does anybody know how to fix the problem
Old Jun 2, 2005 | 04:23 PM
MooFX's Avatar
I just did the cluster swap on mine yesterday.
I ended up opening up the cluster and transfered all the gauges over to my USDM base, or do someone did, transfer the circuit board piece and swap it over, then all will be fine.
Justin
NWP4LIFE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM Factor &raquo;</TD></TR><TR><TD CLASS="quote">Yeah when I got my spoon cluster I had the same problem. I took the circuit board piece off the spoon cluster and put my usdm one on. </TD></TR></TABLE>
try this, it usually does the trick
Old Jun 3, 2005 | 07:37 PM
acura69gsr's Avatar
but does anyone know anything about a the year thnig or the edm ones?
Old Jun 3, 2005 | 08:06 PM
Reid's Avatar
Global Moderator
Default Re: (acura69gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acura69gsr &raquo;</TD></TR><TR><TD CLASS="quote">but does anyone know anything about a the year thnig or the edm ones?</TD></TR></TABLE>
Just swap the gauges or the circuit board piece.
Old Jun 3, 2005 | 08:31 PM
PY 01-0972's Avatar
swap the green piece on the back and you are in business
Old Jun 3, 2005 | 08:33 PM
acura69gsr's Avatar
i understand that guys but i also wanted to know about the edm one the guys says it will work but i waned some more input on it
Old Jun 4, 2005 | 10:11 AM
B2FiNiTY's Avatar
They just told you all the info you need to know and will work on ALL oem cluster whether it be usdm, jdm, or edm.
Old Jun 4, 2005 | 01:16 PM
acura69gsr's Avatar
it all looks to work but i think the temp isn't working right not sure really haven't took it on a trip yet thanks guyd
B2finity i waned to know if i would have to do this mod on a '01 edm one or not
Old Jun 5, 2005 | 06:48 PM
jeremy.'s Avatar
i had to do the same for my ukdm cluster as well
Old Jun 6, 2005 | 12:45 PM
1993sirimback's Avatar
Default Re: (PY 01-0972)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PY 01-0972 &raquo;</TD></TR><TR><TD CLASS="quote">swap the green piece on the back and you are in business</TD></TR></TABLE>
this is true!
Old Jun 6, 2005 | 05:45 PM
IntegraXTR's Avatar
depends, swapping the green piece won't always work unless your new cluster you're putting in has the same white backing case. since there's some years with plugs for the srs/abs lights etc.
just like everybody said above, just swap out the entire backing, and you're golden.
Old Jun 6, 2005 | 06:16 PM
acura69gsr's Avatar
thanks guys got it all working don't like the top speed on the jdm one i have now may pick up the edm one to get the higher top speed
GuitarSlinger78
Aug 16, 2008 01:38 PM
GuitarSlinger78
Nov 14, 2006 10:56 AM
White GSR '01
Apr 14, 2005 08:15 PM
EGJdmJreams
Nov 12, 2004 06:42 PM
MrSmith
12
May 25, 2002 01:13 PM
