starting problems?
I have a 90 crx si w/b16a pr3 ecu vafc golden eagle fuel rail an FPR header 2.50" cat backall emitions are hooked up. Iits been doing this for atlest 2 months now, I have changed the cap and rotor a year ago just did a tune up plugs wires checked the timming its right on. fuel pressure is @ 40psi there are no fuel curves done on the vafc havent had it dynod yet. the car turns over about 3 cycles and I have to give it some gas to get it to start it iddles rough but when driving it runs good it bogs some times though. any help would be greatly appretiated thanks.
I am also throwing a code 3 wich i believe is map sensor
Modified by sullenht at 12:52 PM 6/2/2005
I am also throwing a code 3 wich i believe is map sensorModified by sullenht at 12:52 PM 6/2/2005
i have the same setup minus the fuel rail etc. it takes mine a long time to start also, then sputters then finally fires up. but when running its smooth and strong. im wondering y this happens...ive seens other b16s in rexes do the same also.....maybe its just a b16 thing lol like the v dub tick
well I put in a new fuel filter the car idles better and runse better, I did notice the fuel pressure whent up after the change so I adjusted it back to stock settings but the starting problem is still there. Any other sugestions
ludacole
Jul 19, 2004 10:15 PM
Toda Party
Mar 17, 2002 01:39 AM
