how much for second gear syncro's?
Old Jun 2, 2005 | 10:50 AM
01-0720's Avatar
Default how much for second gear syncro's?
i just went and asked how much a second gear syncro was at the dealer and the dude told me 250 bucks
now i just did a search on here, and people are buying carbon coated 1-5 complete syncro sets for 225 from top gear so i think this dude messed up
my buddies trans is messing up and he needs a second gear syncro, how much should just the parts be? and im guessing len could get me the best price?
thanks alot for any help
and also are itr syncros and 99 si syncros the same thing? cuz i work for honda and maybe could get a deal if they are the same thing
Old Jun 2, 2005 | 12:43 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
Default Re: how much for second gear syncro's? (01-0720)
yes they are the same synchro set as b16 and gsr...dual cone second. since you work @ honda then just get the set for the b16 hydro. don't get just the brass ring cuz more than likely you will need the sleeve and possibly the hub. buy the whole 1/2 set and do it right.
Old Jun 2, 2005 | 12:52 PM
Bbasso's Avatar
I bought my complete syncro set from Gearspeed.com and I am very happy with the price, service and parts.
If I recall correctly it was $275 shipped for all of them.
Old Jun 2, 2005 | 12:55 PM
BlueR's Avatar
honda does not sell synchros by itself...
the price of 250 you were quoted includes the gear set also
Old Jun 2, 2005 | 12:59 PM
canuckr's Avatar
Default Re: how much for second gear syncro's? (BlueR)
I just redid my whole tranny with Gear Speed syncros. The whole set was 275 bucks, not bad, and they work like a charm. Gear Speed makes good stuff.
The reason why there so cheap is because they only come with the syncros.
Old Jun 2, 2005 | 01:05 PM
warwagon's Avatar
i was under the impression that with the gearspeed setup you dont get everything?
Old Jun 2, 2005 | 01:07 PM
Bbasso's Avatar
Default Re: (warwagon)
I got all the syncros...
Nothing missing for me.
Old Jun 2, 2005 | 01:18 PM
warwagon's Avatar
Default Re: (Bbasso)
hrmm!
Old Jun 2, 2005 | 01:37 PM
743power's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by warwagon &raquo;</TD></TR><TR><TD CLASS="quote">i was under the impression that with the gearspeed setup you dont get everything?</TD></TR></TABLE>
you get the synchro rings
more often than not, it is the sleeve or hub that needs to be replaced.
01-0720's Avatar
so with the gearspeed setup, i get syncros for 1 threw 5
whould we need anything else other then what they send, cuz gearspeed sounds like they way to go
if its just popping out of gear, then its the syncro's, right? and does the gearspeed kit come with everything needed to fix that problem? also gonna put in gm syncromesh
and is this somthing i can do, me and my friends are pretty knowledgeably, i just helped a friend completly tear down his motor and replace and bunch of parts and put it back together
thanks alot guys
Old Jun 2, 2005 | 01:43 PM
743power's Avatar
Default Re: (01-0720)
you should call gearspeed and they will tell you what their kits come with and suggest to you what you need to replace.
Old Jun 2, 2005 | 01:53 PM
Gearspeed-Performance's Avatar
The best thing to do is get it torn down. Examine all your parts and determine whether or not if you need a sleeve set or just a synchro. If it is the sleeve set then you can use 99-00 civic Si as replacement since you have easy access to honda parts. The sleeve set is comprised of a sleeve, hub and two synchros for the gears they correspond to. If your feeling confident...go for it
Thank you guys for your recommendations
etank82
Sep 14, 2012 05:01 AM
PRO1
Jul 11, 2011 10:02 AM
brokeHonda
Transmission & Drivetrain
Feb 27, 2010 08:48 AM
stangslayer
Apr 6, 2006 05:36 PM
