HELP! 98 GS-r No power when accelerating
Old Jun 2, 2005 | 07:54 AM
aboysav6's Avatar
Default HELP! 98 GS-r No power when accelerating
Ok...lemme start this off...I was thrwoing a CEL (map sensor)...That was takin care of yesterday...I checked all the vacuum hoses which was all good. When the engine is 1st started it runs fine, but as when it warms up...the car starts trippin, jerkin a lot mainly in 2nd gear, especially in stop & go traffic(embarrasing to be in the middle of the intersection)...seems hesitant...and yes I checked the air temp sensor wiring as well. I tried swapin out 3 diff map sensors and still prob is there. Idle is fine, its just when the car gets goin, it cant really get it goin..Any ideas...im thinkin fuel pump might be bad or the ignitor..any help would be appreciated..thanks
Old Jun 2, 2005 | 10:08 AM
Lan's Avatar
Lan
Default Re: HELP! 98 GS-r No power when accelerating (aboysav6)
Turn key in ignition listen carefully you should hear the whine of your fuel pump. If you have that check your fuel filter. Check your plugs too maybe your car needs a tune up.
Old Jun 2, 2005 | 07:15 PM
aboysav6's Avatar
Default Re: HELP! 98 GS-r No power when accelerating (Lan)
Problem solved...ignitor was crappin....changed cap & rotor as well....thanks anyways..
Old Jun 5, 2005 | 06:54 AM
Satoonxtreme's Avatar
im kindda newbie here, but I have the same problem that you had.. can you tell me exactly what is ignitor looks like? or what does it do? so I can getting smarter thx
Old Jun 5, 2005 | 01:06 PM
PrettyLude's Avatar
ignitor is inside ur distributor with the female terminals plugging into it
crave13k
Sep 2, 2011 11:33 PM
gio_vanni
Jun 11, 2009 12:10 PM
ScandalousCivic
May 12, 2005 07:42 AM
ScandalousCivic
May 10, 2005 06:20 PM
The G2 Racer
Nov 6, 2002 03:29 AM
