Omnipower suspension+brakelines?
Just installed my Omnipower Full coilovers, i tought i could take the brakeline fastenings ? from my old dampers. But the omnipowers are to big to fit the old ones, any tips on how to fix this?.
The thing where you hang upp the brakeline, bottom right on pic.
Pics on how you fixed it would help.
contact kteller, should be able to help you with your omni's, if not, shrug, cut the oldbracket off, and just jb weld it to the shock body.
I'm pretty sure people just zip-tie the brake lines to the shocks. I've heard it's best to put one zip tie around the shock, and then a second zip-tie through the first zip-tie to hold the brake line in place. The idea is to keep the brake line from rubbing on the shock itself...
