9006 6000K Philips HID arrived....dont know how to install...help
Old Feb 8, 2002 | 07:10 AM
GQ 05YellowEVO8's Avatar
Default 9006 6000K Philips HID arrived....dont know how to install...help
I just got my HID kit in today...I was so happy after waiting so long. The problem is on how to connect it. The instructions say:
"that I need to plug the headlight bulb socket from the car directly into the ballast
and then check for correct polarity. If it doesnt work then I'd have to do a 180 and connect the socket the other way."
I'm kinda confused cuz with my old Philips kit, everything was plug and play literally.....but when I tried to plug in my factory low beam socket into the ballast it wouldn't slide in all the way. it seems like I'd have to trim some of the plastic away, so it could clear the locking tabs that are on the ballast. Once the plastic is trimmed away, then the antidisestablishmentarianismet will slide over.
On the othjer hand the kit came with an additional adapter for cars that dont fit properly, I'm wondering if Pep Boys sell 9006 connector style socts so that I can solder the wires on myself. I really dont want to hack up the factory 9006 wiring harness to solder on the adapter though.......I gotta figure out how to do this as simply and cheaply as possible, but hey I cant wait to try out my 6000K's....
On my old Philips kit, there was an adapter which had an inline relay.....this kit has no relay at all and you just have to plug the factory low-beam socket directly into the ballast.....to those of you who have philips kit, what did you guys do? How did the connections go? Can anyone help?
Once I get it lighting I'll post pics.
Old Feb 8, 2002 | 07:50 AM
6SPD_EK's Avatar
Default Re: 9006 6000K Philips HID arrived....dont know how to install...help (TODA RACING)
sorry - I can't help, but are the bulbs you got real philips ultinon bulbs? (I didn't think they fit retro-fit apps )
Old Feb 8, 2002 | 08:23 AM
sgT's Avatar
sgT
the plug is slightly different on the ballast.
It uses a std gm style connector.
Usually the kits come with an adapter cable.
You will have to upgrade your fuses to 20A as well.
Old Feb 8, 2002 | 08:26 AM
B2FiNiTY's Avatar
Default Re: 9006 6000K Philips HID arrived....dont know how to install...help (sgT)
15A fuses should be fine. Thats what I'm running and haven't blown yet.
Old Feb 8, 2002 | 01:34 PM
Default Re: 9006 6000K Philips HID arrived....dont know how to install...help (2000-4DRGSR)
Well, I looked at the bulbs and the part numbers on them match up with the part numbers of the bulbs of those kits sold by http://www.autolamps-online.com
Old Feb 8, 2002 | 01:35 PM
Default Re: 9006 6000K Philips HID arrived....dont know how to install...help (B2FiNiTY)
I decided to slap in the 20A fusues just for extra protection.
Old Feb 8, 2002 | 06:27 PM
Edwin's Avatar
Actually it would be less protection with 20amp fuses. 15amps will blow protecting the circuit sooner than a 20amp fuse.
Old Feb 8, 2002 | 07:12 PM
Duck Sauce's Avatar
Default Re: 9006 6000K Philips HID arrived....dont know how to install...help (Edwin)
Just get it professionaly installed. Believe me it's worth the money. Don't DoEs AnYoNe KnOw WheRe I CaN GeT SoMe StRObE LiTEZ AnD LiGhT uP WiNdShiElD NoZzLeS?? around with HID's if you're unsure of what you are doing. A good car stereo/alarm shop should be able to do it for under $75.
Old Feb 9, 2002 | 07:18 AM
hummm....I nevet thought of that...ohh well the instructions recommended 15A anyway, so I'll switch them back
Old Feb 9, 2002 | 07:19 AM
Default Re: 9006 6000K Philips HID arrived....dont know how to install...help (www.s4-mtm.com)
i actually got them installed
Nerologic
May 6, 2007 08:41 AM
MikeTV
Jan 26, 2005 04:02 PM
GQ 05YellowEVO8
Feb 9, 2002 10:58 AM
