frankenstein motor
i have a d16 vtech out of a 92-95 civic si and i want to put the head from a d15 on the d16 bottom end because i dont have a computer that can compensate the vtech would there be any advantages of using the d15 head on the d16 bottom end and would the frankenstein engine work
You could probably rechip your ecu to use vtec, (not vtech FYI). There was a thread yesterday with a guy comparing the d16z6 p28 to the d15 saying the only differences were the lack of resistors on the d15 ecu. Said you could probably do it for $10 if you have a soldering iron, if not it would be about $30.
edit: this is the thread talking about rechipping the ecu. https://honda-tech.com/zerothread?id=1263509
TehMoonRulz
Apr 4, 2005 06:38 PM
d15, d16, engine, frankebstien, frankenstein, frankenstien, frankinsty, head, honda, hp, make, mini, moter, motor, school, z6
