Can i use a b16 or b18c girdle in my b20 block?
Will a b16 or b18c girdle fit a b20 block? I assume you have to use the main crank caps from the b16 or b18c in order to use the girdle. and if i remember right the girdle differ from each other. if any additional info i left out you can help point me the right direction in what i need to know in order to utilize one of these in my b20 block thanks.
only b18s's came with block girdles
b16's do not have them unless its a b16b
to use a stock girdle you need a b18c oil pan, pick up, whindage tray, and their main bolts,
you can use the stock main caps but they need to be machined
just get a z10 blokc girdle to avoide the machining
